Hi @DennisMidjord,
The cPanel API is rejecting the authentication requests. The reason for this is that cPanel v74 removed XML support from their API: https://documentation.cpanel.net/display/CKB/cPanel+Deprecation+Plan
The old cPanel API is used by old versions of WHMCS. As far as I'm aware there isn't a workaround or shim layer available.
You will need to roll back the cPanel upgrade, or update WHMCS to 7.3 or above.
Posted by WHMCS John,
Reputation Points
Go to this post
