snake Posted July 10, 2019 Share Posted July 10, 2019 I am using whmcs CPANEL module to provision users on my GURU reseller account. This was working when I originally set it up, but is now generating an order when I try to accept orders, presumably since my last whmcs update. Any idea why? The settings it is referring to do not exist in the module configuration, so I assume they must relate to some settings on the reseller plan. Order Accept Encountered ProblemsInvalid numeric value “Create Support Ticket” for the “maxpop” setting. Invalid numeric value “None” for the “quota” setting. Invalid numeric value “None” for the “bwlimit” setting. 0 Quote Link to comment Share on other sites More sharing options...
snake Posted July 10, 2019 Author Share Posted July 10, 2019 nevermind, solved it 🙂 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 10, 2019 Share Posted July 10, 2019 14 minutes ago, snake said: nevermind, solved it 🙂 it might be useful to mention the solution in case somebody else gets this error in the future. 🙂 0 Quote Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted July 11, 2019 Share Posted July 11, 2019 @snake Im assuming the resolution was to replace the "None" values with something else? 0 Quote Link to comment Share on other sites More sharing options...
snake Posted July 11, 2019 Author Share Posted July 11, 2019 I had not previously set and of the values under advanced settings, so I assume it must have previously used the settings from CPANEL/WHM. However that doesn't seem to work now, and I had to put values in the module advanced settings as well. Also WHMCS seems to have put some invalid default text in some of the fields as well, which are expecting numerical value. e.g. “Create Support Ticket” for the “maxpop” setting and others 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Technical Analyst II WHMCS Lawrence Posted July 11, 2019 WHMCS Technical Analyst II Share Posted July 11, 2019 This would suggest that the product in question was set to use the AutoRelease module instead of cPanel at some point, and still had those values for the advanced settings after switching. If this occurs again, I'd recommend using the Advanced Mode option on the Module Settings for the affected product to correct as needed. 0 Quote Link to comment Share on other sites More sharing options...
snake Posted July 11, 2019 Author Share Posted July 11, 2019 that is exactly what I did, as per my last reply above. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Technical Analyst II WHMCS Lawrence Posted July 12, 2019 WHMCS Technical Analyst II Share Posted July 12, 2019 That's good to hear. Hopefully it worked 🙂 0 Quote Link to comment Share on other sites More sharing options...
ghmercado Posted June 29, 2022 Share Posted June 29, 2022 On 7/11/2019 at 10:08 PM, snake said: I had not previously set and of the values under advanced settings, so I assume it must have previously used the settings from CPANEL/WHM. However that doesn't seem to work now, and I had to put values in the module advanced settings as well. Also WHMCS seems to have put some invalid default text in some of the fields as well, which are expecting numerical value. e.g. “Create Support Ticket” for the “maxpop” setting and others hi this same issue has me stumped. I just updated to 8.5.1 it had been working fine a week or so previous. I went to Systems Settings > Products and Services, then the tab 'Module Settings' Module name is CPanel I then configured Metric Billing > Disk Space, Bandwidth and Email accounts, then kept the rest at OFF I put values at each I still get the same error. I tried Re - saving the Packages in WHM and re-syncing / refresh the Server with WHMCS, still same error. any help appreciated thank you very much 0 Quote Link to comment Share on other sites More sharing options...
ghmercado Posted June 30, 2022 Share Posted June 30, 2022 ok i fixed it. The issue was I couldn't find the 'advanced settings' on the product module's page. Instead it's a small link at the bottom titled 'switch to advanced mode' I then had to add values to the bandwidth, email accounts, space and so on. This used to work flawlessly before i had to do this and is likely due to an update. I worry now what else might not be working due to updates. 1 Quote Link to comment Share on other sites More sharing options...
Dronehaze Posted May 15, 2023 Share Posted May 15, 2023 I also upgraded to the new version. I have noticed that in "Advanced Mode" the fields are autowritten to "none". They just have to delete them. 0 Quote Link to comment Share on other sites More sharing options...
