Rabab Posted July 27, 2018 Share Posted July 27, 2018 Hi all, I added on my platform whmcs 4 product addons, I configured them all in the same way (Payment Type = Recurring, ....) But when these addons are displayed in order process, it gives me 2 Annually addons and two more recurring (see the screenshot) I would like to ask if you have any idea about this little problem? Thank you for your collaboration. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 28, 2018 Share Posted July 28, 2018 21 hours ago, Rabab said: I would like to ask if you have any idea about this little problem? which version of WHMCS are you using, and which orderform template ?? 0 Quote Link to comment Share on other sites More sharing options...
Rabab Posted July 31, 2018 Author Share Posted July 31, 2018 Hi Brian, Version of WHMCS : 7.5.1 Orderform template : Use Specific Template -> Modern Thank you for your help ! 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 31, 2018 Share Posted July 31, 2018 Hi @Rabab, first thought would be to go through the product addons setup for each of them and make sure they are actually set as recurring - I know that you probably have done this already, but it's good to double-check again. i'd then try switching the orderform template to standard_cart - assuming you haven't modified it, that should give you an indication of whether it's a template issue with Modern, or a settings/WHMCS issue. 0 Quote Link to comment Share on other sites More sharing options...
Rabab Posted July 31, 2018 Author Share Posted July 31, 2018 Hi Brian, I re-checked and found that all product addons are actually set as recurring. I even changed the template order to Standard but it changes nothing, I had the same problem. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 1, 2018 Share Posted August 1, 2018 Hi @Rabab, On 31/07/2018 at 16:39, Rabab said: I re-checked and found that all product addons are actually set as recurring. I thought as much - but still worth checking. On 31/07/2018 at 16:39, Rabab said: I even changed the template order to Standard but it changes nothing, I had the same problem. then it might be worth opening a ticket with Support (or Reseller Support if you don't get your license direct from WHMCS)... it's difficult to tell without seeing the site, and Support might be able to determine if it's a configuration issue. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted August 1, 2018 WHMCS Product Manager Share Posted August 1, 2018 Hi @Rabab, The Modern order form template is deprecated: https://docs.whmcs.com/Discontinued_Order_Form_Templates#Deprecated_Order_Form_Templates Please switch to the Standard Cart or one of its children: https://docs.whmcs.com/Standard_Order_Form_Templates#Templates 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 2, 2018 Share Posted August 2, 2018 11 hours ago, WHMCS John said: Please switch to the Standard Cart or one of its children: https://docs.whmcs.com/Standard_Order_Form_Templates#Templates John - he already said that he tried switching to SC and it made no difference... and changing to any of the children templates would be the same as SC by the time he got to the addons step in the cart. 0 Quote Link to comment Share on other sites More sharing options...
Rabab Posted August 3, 2018 Author Share Posted August 3, 2018 Hi all, Thank you for your feedback. I would like to ask In which case the whmcs should show me "recurring" and in which case it should display "Annually"! Since in the configuration, the Payment Type = Recurring and the price config I activate the annual (see attached file) 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted August 4, 2018 Share Posted August 4, 2018 this is what I see, using the Modern template, with 4 identical product addons, recurring with only an annual price set. or using Standard_cart... I can't seem to recreate your 'recurring' issue. 0 Quote Link to comment Share on other sites More sharing options...
