Problem with WHMCS Cron Report Timing
  • WHMCS Technical Analyst II
Hello @jacksony
You can check this by navigating to Setup > Automation settings  and looking at the "Last Run" time value in the green box , then compare it with the time in the right corner of the admin UI. They should match or be within 5 minutes of each other (assuming your cron is executed every 5 minutes).
We have some cron specific documentation at the bottom of this page that may also help: https://docs.whmcs.com/Changing_Timezone
My personal recommendation would be to specify a date.timezone value in the cron command itself. The reason for this is then you can be absolutely sure it's executing under the correct timezone, and it saves having to investigate any difference between the timezone your php-cli is using vs what is set for this in the PHP configuration applied to web pages like WHMCS. Below is an example of running the cron.php script under the Europe/London timezone:
php -d "date.timezone=Europe/London" -q /path/to/crons/cron.php
I hope this helps.
