Adding custom/tracking codeto body tags
spartanza
13 minutes ago, spartanza said:
I need to add one line of code within the body tags of the website - that is immediate. But ongoing, I would like to know how to do this easily and the best way with WHMCS so I can handle it myself in the future.
to insert code between the <body> and </body> tags, you could use a ClientAreaHeaderOutput hook - so in the hook below, it's adding some CSS styling to the page, but you could use it to add js or any other code too...
<?php
function insert_body_code_hook($vars)
	return <<<HTML
<style>.view-cart-tabs {display: none;}</style>
HTML;
add_hook("ClientAreaHeaderOutput",1,"insert_body_code_hook");
the only line in the hook that you should need to change is what goes between the two HTML tags in it - that's the code that will be added to the template.
I suppose in some circumstances you may need to edit the template (header.tpl) instead, but usually using a hook will be easier.
On 22/08/2018 at 8:33 PM, spartanza said:
admins please delete
@spartanza can I please refer you to our WHMCS.Community Guidelines, specifically guideline 2.5
On 7/09/2016 at 8:55 PM, WHMCS ChrisD said:
2.5 Your posts assist other users, please do not delete content if you find an answer, please share this solution to help other users.
