problem in run cronjob
Hello 3245,
Thanks for your post on the WHMCS community forums.
Firstly, please update the start of the cron to php -q
Secondly, please try adding -vvv to the end of the cron this will enable debug reporting and should show errors in the cron output email.
Lastly, please enable display errors under Setup > General Settings > Other > Display Errors and then go into your servers terminal window and execute your cron with the following at the end -F all -vvv ​and check the output for any errors
  • 3 weeks later...
  • WHMCS Product Manager
This is due to the size of your MySQL database requiring a lot of PHP memory to be generated.
You can increase the memory_limit in your php.ini or disable the backup process under Setup > Other > Database Backups.
In version 7.3 we've added the ability to let cPanel handle the backup process - instead of PHP - which negates this problem.
