Daniel80 Posted June 9, 2016 Share Posted June 9, 2016 Hi fellows! I have installed whmcs and now setting up everything and when i come to "servers" and under "server details" and have cPanel selected under type with login and password. When i press Test connection i got "FAILED: Array" Have put in hostname, ipadress, ns1 and ns2 with ip. I belive there something simple I'm just forgot? All help is welcome Best regards Daniel 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted June 9, 2016 Share Posted June 9, 2016 have you entered either username/password or username/access hash? if so, are they correct?? http://docs.whmcs.com/CPanel/WHM#Adding_a_cPanel_Server 0 Quote Link to comment Share on other sites More sharing options...
twhiting9275 Posted June 9, 2016 Share Posted June 9, 2016 IIRC there was an issue with this if you had advanced two factor authentication enabled (ie: duo auth, or google auth). Make sure that the user can login directly with the user and password, not using 2fa of any kind 0 Quote Link to comment Share on other sites More sharing options...
Daniel80 Posted June 10, 2016 Author Share Posted June 10, 2016 have you entered either username/password or username/access hash? if so, are they correct?? http://docs.whmcs.com/CPanel/WHM#Adding_a_cPanel_Server Yes i use my login and password and they are correct. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted June 13, 2016 WHMCS Product Manager Share Posted June 13, 2016 Hi, There are potentially a number of causes for this error: The cPanel server has Force SSL Redirect enabled in WHM but the secure connection checkbox is not tick on the server in WHMCS Firewall restriction: The WHMCS server's IP address needs to be able to communicate with cPanel /etc/hosts.allow : WHM allows managing /etc/hosts.allow to deny all. You will need to add the WHMCS server's IP address to the /etc/hosts.allow list above the deny rule. This can also be caused by SELinux being enabled on the cPanel server. "Limit logins to verified IP addresses" is enabled in WHM under "Security Center >> Configure Security Policies". This either needs the IP under Help > License Information or to be disabled at your discretion. 0 Quote Link to comment Share on other sites More sharing options...
