miguelacabtrera Posted May 9, 2014 Share Posted May 9, 2014 Hi good day to all I have a problem with whois and domain. Mx When I search domains. Mx not work. With the other domains works well. Now check and if I have enabled port 43 on my server I hope someone can help thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted May 13, 2014 WHMCS Product Manager Share Posted May 13, 2014 Hi, I've tested this here in v5.3.7 and can confirm the status of .mx domains is being reported correctly. Please ensure there is nothing blocking connections between your server and whois.nic.mx. 0 Quote Link to comment Share on other sites More sharing options...
homepageonline Posted May 14, 2014 Share Posted May 14, 2014 May I ask since the whois is working what registrars are available for .mx domains that won't break the bank? Thanks 0 Quote Link to comment Share on other sites More sharing options...
miguelacabtrera Posted May 14, 2014 Author Share Posted May 14, 2014 The problem is intermittent sometimes works and sometimes does not work anymore. I'm upgrading to see if it corrects **** thanks 0 Quote Link to comment Share on other sites More sharing options...
miguelacabtrera Posted May 16, 2014 Author Share Posted May 16, 2014 Muchas gracias por sus respuestas Actualize a 5.3.7 y parece que ya funciona todo correctamente - - - Updated - - - Thank you very much for your answers Actualize to 5.3.7 and it seems that everything works properly and 0 Quote Link to comment Share on other sites More sharing options...
miguelacabtrera Posted May 16, 2014 Author Share Posted May 16, 2014 Hi all the problem with whois back, I can not find domains with termination. Mx Attached screenshots 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted May 16, 2014 Share Posted May 16, 2014 the English version of that error message is: "There was a problem connecting to the domain registry. Please try again later". i'm wondering if there is a network or firewall issue between your server and the .mx whois server? 0 Quote Link to comment Share on other sites More sharing options...
miguelacabtrera Posted May 18, 2014 Author Share Posted May 18, 2014 looking for a bit I found that for the whois is necessary to open port 43 on the server I've got this port enabled. What makes me weird is that only happens for about 2 hours in the day, after this time works well whois Thanks for your answers 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Technical Analyst II WHMCS Lawrence Posted May 18, 2014 WHMCS Technical Analyst II Share Posted May 18, 2014 When this is occurring, I would recommend trying to check the availability of a .MX domain from the client area (any domain) and click the WHOIS link. A new window will open with the WHOIS details for the domain. I suspect it is a connectivity issue (perhaps a block by the .MX registry for too many lookups or something similar) and any errors there will need to be reported to the .MX registry for investigation and they should be able to resolve it for you. 0 Quote Link to comment Share on other sites More sharing options...
