Upgraded to 5.2.13 - now search box doesn't work in top right corner
sahostking
Thanks I tested and it's now working.
Ok so I am not getting this fix.
I have a folder called templates_c in the remote server. In that folder is one file called index.php. There is no cached file in that folder to delete or clear. Can someone please clarify what you mean by clearing the templates_c file?
Thanks
Not for me. I have cleared the cache in the browser and search box does not work. What about the clearing of the templates_c folder? I have one folder with an index.php file in it with one line of code in it. Am I suppose to delete the index.php file? How do you clear the cache of a folder? What am I missing here? Can someone please answer me?
If you have created a custom "Admin" template based on the V4 template then you need to copy over the new V4 "head.js" to your custom template folder. You also need to replace the old search box code in your "header.tpl" from a previous version with the new code that matches that head.js code.
For me I replaced this in the "header.tpl" file in my custom admin template:
<input type="text" id="intellisearchval" />
<img src="images/icons/delete.png" alt="Cancel" width="16" height="16" class="absmiddle" id="intellisearchcancel" />
</div>
with:
<form id="frmintellisearch">
<input type="hidden" name="intellisearch" value="1" />
<input type="hidden" name="token" value="{$csrfToken}" />
<input type="text" id="intellisearchval" name="value" />
</form>
Which I found in the new V4 template -
OK, it turns out the intellisearch issue is a swiftmodders issue for me. Moved away from sm to v4 theme until there is a fix. Thanks for this thread. Was doing my head in.
I opened a ticket to alert them about it, so hopefully a quick fix can be done.
Thanks
That sounds like you are looking at the wrong templates_c folder.
For security it is recommended that the templates_folder is moved outside of the main public structure.
See here
However, the default install puts one in the whmcs/templates folder which could be confusing and is probably the one you are looking at.
However, your problem does not stop there.
The facility to empty the template cache (which would have emptied the correct one) got broken in the upgrade to 5.2.13 so you have to empty the cache manually :(
Trevor
I found the templates_c folder in the root directory above the public_html.. but clearing that still did not fix the issue. The search box says invalid token. Also when you go to submit an answer to a support ticket it says that there is already a response to that ticket when there isn't. When will WHMCS start testing this stuff before they post a patch? Everytime we patch something it breaks other things.
Oddly, I have 2 sites running 5.2.13 and one has this issue, the other doesn't. I'm getting "invalid token" when using the search box at the top right of the header (in both blend and V4) and also when trying to insert a predfined reply in a support ticket. Emptied templates_c, cleared cache and still no luck.
