easyhosting Posted October 17, 2010 Share Posted October 17, 2010 Hi when i use the unsuspend buttom within a clients products/services page all i get is "Module Command Error (Curl Error) Operation timed out after 150000 milliseconds with 3250 bytes received - code: 28" 0 Quote Link to comment Share on other sites More sharing options...
bear Posted October 17, 2010 Share Posted October 17, 2010 Does it work to suspend the same account in the first place? That appears to indicate cURL can't connect. Seen this thread? http://forum.whmcs.com/showthread.php?t=25678 0 Quote Link to comment Share on other sites More sharing options...
easyhosting Posted October 17, 2010 Author Share Posted October 17, 2010 Does it work to suspend the same account in the first place? answer: NO Seen this thread?http://forum.whmcs.com/showthread.php?t=25678 Server setup is correct as its only the suspend/unsuspened that i get any error 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted October 18, 2010 WHMCS Product Manager Share Posted October 18, 2010 This suggests your server is taking longer than 150 seconds to suspend/unsuspend an account. You'll need to reduce the time taken or open a support ticket for a module with a longer timeout. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted October 18, 2010 Share Posted October 18, 2010 Ours takes a max of about 10 seconds to do these (to completion), so if yours it taking more than 2-1/2 minutes, something more is wrong on that server, I believe. What are the server loads when you're trying this? Do the logs have anything useful in them about this? 0 Quote Link to comment Share on other sites More sharing options...
