samiryours Posted December 30, 2009 Share Posted December 30, 2009 I am registering all my domain through onlinenic, it was working well...but two days before it stoped working suddenly, and i am unable to access support.onlinenic.com error message Forbidden You don't have permission to access / on this server. Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request. i dont know what to, can anyone confirm if they can access http://support.onlinenic.com i will be great full to him/her... And one more problem with them is my clients are unable to managed their domains through whmcs system, don't know why, error Registrar Error Connection Failed - 110 - Connection timed out please help and if anyone having same same problem let me know.... 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted December 30, 2009 WHMCS Product Manager Share Posted December 30, 2009 http://support.onlinenic.com/ is working fine from here. 0 Quote Link to comment Share on other sites More sharing options...
SiteSeal-Developer Posted December 30, 2009 Share Posted December 30, 2009 try deleteing your cashe. You also may want to check your .htacsess files within that directory. Also just to let you know i can see the website from here ok. 0 Quote Link to comment Share on other sites More sharing options...
Roger Posted December 30, 2009 Share Posted December 30, 2009 Fine from here as well... 0 Quote Link to comment Share on other sites More sharing options...
you86 Posted January 9, 2010 Share Posted January 9, 2010 error Registrar Error Connection Failed - 110 - Connection timed out please help and if anyone having same same problem let me know.... I am getting same error Registrar Error Connection Failed - 110 - Connection timed out Did you find solution? 0 Quote Link to comment Share on other sites More sharing options...
you86 Posted January 13, 2010 Share Posted January 13, 2010 perhaps no one is going to reply but problem was port 20001 was blocked in firewall and this is the port which whmcs use to connect to online nic if you guys still have problem then open port and then check it out 0 Quote Link to comment Share on other sites More sharing options...
bargainhost Posted February 2, 2010 Share Posted February 2, 2010 Im getting a different error: Connection Failed - 111 - Connection refused Port 20001 is already whitelisted. 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted February 2, 2010 Share Posted February 2, 2010 Im getting a different error: Connection Failed - 111 - Connection refusedPort 20001 is already whitelisted. SAME problem here today . Connection Failed - 111 - Connection refused Port 20001 is allowed . 0 Quote Link to comment Share on other sites More sharing options...
wqqar Posted February 2, 2010 Share Posted February 2, 2010 Same error here ........ Connection Failed - 111 - Connection refused 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted February 2, 2010 Share Posted February 2, 2010 now it works again for me , I suppose there was a problem at onlinenic.com. 0 Quote Link to comment Share on other sites More sharing options...
wqqar Posted February 2, 2010 Share Posted February 2, 2010 now it works again for me , I suppose there was a problem at onlinenic.com. But, I'm still facing the same issue 0 Quote Link to comment Share on other sites More sharing options...
wqqar Posted February 2, 2010 Share Posted February 2, 2010 OK... It is working for me for now .. It means there was nothing wrong with the port settings etc. It was clearly an onlinenic issue. 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted February 2, 2010 Share Posted February 2, 2010 it does not work again ... 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted February 2, 2010 Share Posted February 2, 2010 the problem continues and I received this reply from onlinenic Please be informed that your ip was not blocked here. And it is ok, the problem may caused by port 20001, since telneting http://www.onlinenic.com 20001 get connection failed. So we suggest that you may change the port to 30009, and it works well. Thanks for your cooperation. How to change port 20001 in 30009 in WHMCS please ? 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted February 3, 2010 Share Posted February 3, 2010 the problem continues and I received this reply from onlinenic Please be informed that your ip was not blocked here. And it is ok, the problem may caused by port 20001, since telneting http://www.onlinenic.com 20001 get connection failed. So we suggest that you may change the port to 30009, and it works well. Thanks for your cooperation. How to change port 20001 in 30009 in WHMCS please ? I received this from onlinenic > We are very sorry for inconvenience caused on you, it may be unstable connection at that period. And please be informed that it is ok now, please check. Thanks for your cooperation and understanding. > However I recommend WHMCS developers to give us possibilities to use port 30009 in replacement of 20001 in case the problem repeat . Or if WHMCS could use automatically port 30009 in case of 20001 is not responding could be fantastic too. 0 Quote Link to comment Share on other sites More sharing options...
wqqar Posted February 23, 2010 Share Posted February 23, 2010 and here it is again ......... Registrar Error Connection Failed - 111 - Connection refused Is there any solution to this ???? 0 Quote Link to comment Share on other sites More sharing options...
Patty Posted February 23, 2010 Share Posted February 23, 2010 I'm getting that too for the first time today. But their site is down, that might be it. 0 Quote Link to comment Share on other sites More sharing options...
doongoan Posted March 5, 2010 Share Posted March 5, 2010 I have the same issue now any idea how to change the port in whmcs? I tried to edit the file: /modules/registrars/onlinenic/onlinenic.php but it's encoded. 0 Quote Link to comment Share on other sites More sharing options...
imamo Posted March 6, 2010 Share Posted March 6, 2010 From the day i bought WHMCS I can't use OnlineNic register module. So it will be nice guys to solve this problem and also some other problem (missing badly needed futures) ASAP not is some future releases! 0 Quote Link to comment Share on other sites More sharing options...
Lawrence Posted March 6, 2010 Share Posted March 6, 2010 Nobody should be using OnlineNIC anymore anyways. They are clearly going under thanks to the lawsuit from Verizon, and I wouldn't be surprised if they are stripped of their registrar status soon too. 0 Quote Link to comment Share on other sites More sharing options...
Patty Posted March 7, 2010 Share Posted March 7, 2010 Nobody should be using OnlineNIC anymore anyways. They are clearly going under thanks to the lawsuit from Verizon, and I wouldn't be surprised if they are stripped of their registrar status soon too. Not really: http://www.domainnamenews.com/legal-issues/verizon-may-be-unable-to-collect-33-million-judgment-experts-say/3659 0 Quote Link to comment Share on other sites More sharing options...
rdavis Posted March 7, 2010 Share Posted March 7, 2010 I am registering all my domain through onlinenic, it was working well...but two days before it stoped working suddenly, and i am unable to access support.onlinenic.com error message Forbidden You don't have permission to access / on this server. Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request. i dont know what to, can anyone confirm if they can access http://support.onlinenic.com i will be great full to him/her... And one more problem with them is my clients are unable to managed their domains through whmcs system, don't know why, error Registrar Error Connection Failed - 110 - Connection timed out please help and if anyone having same same problem let me know.... We also had no way to use OnlineNIC, but I did some research (we've been through this many times before) and found the fiber backbone outside of Texas where OnlineNic's server farm is located was accidental damaged in a dig-up. So all the routing by the www was down to the whole southwest area. We conducted a ping test (failed) then a traceRT and found it timed out just before Texas. Then we called a fiber rescue friend we work with and they said there was a outage due to some construction company not getting locates before they dug. Really dumb! So there was over a 2 day outage. By the way, OnlineNIC's support is over seas now! No longer in Oakland, CA. The last time I knew of an cut fiber was a US West cable and it cost the contractor 1 million an hour in loss communication time, he only had a 5 million insurance bond. He was broke in after the 5th hour. 0 Quote Link to comment Share on other sites More sharing options...
rdavis Posted March 8, 2010 Share Posted March 8, 2010 Not really: http://www.domainnamenews.com/legal-issues/verizon-may-be-unable-to-collect-33-million-judgment-experts-say/3659 Read more: http://www.internetnews.com/security/article.php/3794306/Verizons+Cybersquatter+Based+in+China.htm 0 Quote Link to comment Share on other sites More sharing options...
mailgser Posted November 20, 2010 Share Posted November 20, 2010 I also have this problem. How can I open the port? perhaps no one is going to reply but problem was port 20001 was blocked in firewall and this is the port which whmcs use to connect to online nicif you guys still have problem then open port and then check it out 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted November 22, 2010 WHMCS Product Manager Share Posted November 22, 2010 Ask your hosting provider to do it. 0 Quote Link to comment Share on other sites More sharing options...
