ausloki Posted April 14, 2009 Share Posted April 14, 2009 For some reason i'm getting errors trying to download the pdf invoice. i even cleared the template_c cache first. Problem resolved, it was an issue with the pdfconfig image format. retyped using Image(ROOTDIR. instead of Image(dirname(__FILE__).' So once i worked out my paths were relative in original file it has been resolved. All else no problems so far 0 Quote Link to comment Share on other sites More sharing options...
minadreapta Posted April 14, 2009 Share Posted April 14, 2009 i have to say, the 'default' template is stunning! David i think there is something wrong with your ssl cert for pingex client area. 0 Quote Link to comment Share on other sites More sharing options...
Jay Posted April 14, 2009 Share Posted April 14, 2009 i have to say, the 'default' template is stunning! David Do you mean portal? The 'default' template looks the same to me. 0 Quote Link to comment Share on other sites More sharing options...
ipglobe Posted April 14, 2009 Share Posted April 14, 2009 I made several modifications to the templates of the customer, now I have to redo some because the codes have changed. Another detail, everything changed in the translation from Portuguese of Brazil is so difficult to work with the whmcs. 0 Quote Link to comment Share on other sites More sharing options...
Gears Posted April 14, 2009 Share Posted April 14, 2009 I'll be waiting for the stable version :\ 0 Quote Link to comment Share on other sites More sharing options...
baileysemt Posted April 14, 2009 Share Posted April 14, 2009 I would love to be able to download it, but MaxMind keeps blocking my order. Must be "high-fraud" to have your IP resolve to within 60 miles of your snail-mail address.... Bailey 0 Quote Link to comment Share on other sites More sharing options...
PingEx.com Posted April 14, 2009 Share Posted April 14, 2009 Thank for the headdup on the SSL, will look into it, i know it needs renewed next month. Yep i did mean the portal theme Dvaid 0 Quote Link to comment Share on other sites More sharing options...
simplybe Posted April 14, 2009 Share Posted April 14, 2009 I have downloaded it and installed it but i can't get it to work with my current v3 license An incorrect license key has been used The IP Address your system is using has changed The domain you are using has changed The directory you are using has changed So no way of testing it unless i upgrade my current v3 install ? I thought we would be able to test this without altering our current v3 install. Any ideas 0 Quote Link to comment Share on other sites More sharing options...
yukiko Posted April 14, 2009 Share Posted April 14, 2009 I have downloaded it and installed it but i can't get it to work with my current v3 license An incorrect license key has been used The IP Address your system is using has changed The domain you are using has changed The directory you are using has changed So no way of testing it unless i upgrade my current v3 install ? I thought we would be able to test this without altering our current v3 install. Any ideas need to have a valid licence to install it meaning ya have to use current one already installed. that's fine but the branding free isn't working for me at the moment 0 Quote Link to comment Share on other sites More sharing options...
cbtrussell Posted April 14, 2009 Share Posted April 14, 2009 Does anyone else have an issue with some of the admincp pages being WAY to wide... like 1600 pixels? For example: - add new client - view client - configuration > general settings I get the same issue in IE7 and FF3. 0 Quote Link to comment Share on other sites More sharing options...
Stream101 Posted April 14, 2009 Share Posted April 14, 2009 http://wiki.whmcs.com/Version_4.0_Release_Notes#New_Admin_Area_Design: New Admin Area Design The new admin area design is designed for a monitor resolution of width 1280 or larger. Smaller screens may have horizontal scrolling. Maybe this will explain it. 0 Quote Link to comment Share on other sites More sharing options...
SRobinson Posted April 14, 2009 Share Posted April 14, 2009 I have downloaded it and installed it but i can't get it to work with my current v3 license An incorrect license key has been used The IP Address your system is using has changed The domain you are using has changed The directory you are using has changed So no way of testing it unless i upgrade my current v3 install ? I thought we would be able to test this without altering our current v3 install. Any ideas If you go into your WHMCS client area on this site, go to the product with the V3 license, click something like "Re Issue License" then try logging in again on your own site it should work! 0 Quote Link to comment Share on other sites More sharing options...
JeddaHost Posted April 14, 2009 Share Posted April 14, 2009 Could some one please post a screen shot of the new admin area ? 0 Quote Link to comment Share on other sites More sharing options...
SRobinson Posted April 14, 2009 Share Posted April 14, 2009 Here we go! Im not willing to show everyone the info from my admin area, but if someone else is feel free to upload yours! New client area at blackwhite-hosting.co.uk/billing. Site not finished yet And i havent implemented there new layout either. 0 Quote Link to comment Share on other sites More sharing options...
cbtrussell Posted April 14, 2009 Share Posted April 14, 2009 (edited) http://wiki.whmcs.com/Version_4.0_Release_Notes#New_Admin_Area_Design: Maybe this will explain it. Thanks, I saw that but the machine I'm on now is 1280w and these pages are definitely way beyond what could be considered 'normal'. Attached is a screenshot of the general config page in FF3. Can anyone else confirm the pages I listed above are wide for them as well? Edited April 14, 2009 by cbtrussell 0 Quote Link to comment Share on other sites More sharing options...
SRobinson Posted April 14, 2009 Share Posted April 14, 2009 Thanks, I saw that but the machine I'm on now is 1280w and these pages are definitely way beyond what could be considered 'normal'. Attached is a screenshot of the general config page in FF3. Can anyone else confirm the pages I listed above are wide for them as well? Hi! Im running FF3 on a res of 1280*1024 and all of the pages mentioned above work fine for me! Obviously the vertical scroll bar, but no horizontal scrollbar for me! They all appear fine Scott 0 Quote Link to comment Share on other sites More sharing options...
Stream101 Posted April 14, 2009 Share Posted April 14, 2009 Thanks, I saw that but the machine I'm on now is 1280w and these pages are definitely way beyond what could be considered 'normal'. Attached is a screenshot of the general config page in FF3. Can anyone else confirm the pages I listed above are wide for them as well? From your SS I think a file might be corrupted in your template. Try reuploading the template in Binary format and see if that works 0 Quote Link to comment Share on other sites More sharing options...
cbtrussell Posted April 14, 2009 Share Posted April 14, 2009 One of my developers figured it in about 2 minutes. I never would have figured it out in a million years. The fixed field widths (specified in characters) combined with a default font of "Lucida Grande" was the culprit. I think my Lucida Grande originated from a Mac, and apparently the width calc goes haywire. I found similar reports in a quick Google search. Anyway, I deleted the font and all is well. Thanks for the confirmation that everything looked fine for you guys so we could proceed to dig a little deeper. 0 Quote Link to comment Share on other sites More sharing options...
merlinpa1969 Posted April 15, 2009 Share Posted April 15, 2009 Are you guys really testing on your LIVE sites? this is what I was told "You should upgrade your live install to give it a thorough testing now it's at the release candidate stage. It is not beta." I will test it with a complete backup but there is no way that I will put my business in jeopardy for a RC ...... Like someone earlier said, I will wait for the final release 0 Quote Link to comment Share on other sites More sharing options...
PingEx.com Posted April 15, 2009 Share Posted April 15, 2009 i only have my own sites in the billing system so means i can test it. the currency fix file would be useful to have david 0 Quote Link to comment Share on other sites More sharing options...
merlinpa1969 Posted April 15, 2009 Share Posted April 15, 2009 Yes I agree for you thats great, I just cant believe that the devs are expecting people to upgrade their LIVE sites... 0 Quote Link to comment Share on other sites More sharing options...
Redsign Posted April 15, 2009 Share Posted April 15, 2009 Not sure if it's a bug, but I personally think it looks wrong: The first domain seems to get it's own row? 0 Quote Link to comment Share on other sites More sharing options...
VicToMeyeZR Posted April 15, 2009 Share Posted April 15, 2009 dang this sucks.. I check the forums daily, and all 250 gone already. what a crock 0 Quote Link to comment Share on other sites More sharing options...
[JSH]John Posted April 15, 2009 Share Posted April 15, 2009 The new version looks amazing! I can't wait for the stable release. 0 Quote Link to comment Share on other sites More sharing options...
ljesh Posted April 15, 2009 Share Posted April 15, 2009 I have 2-3 signups weekly and I am using it LIVE. I don't think we can test it that good if we don't really use it, every purpose it may have. I noticed some things that look wrong to me, some that do not work... but it still looks and works great. 0 Quote Link to comment Share on other sites More sharing options...
