zoilodiaz Posted December 18, 2008 Share Posted December 18, 2008 Hello, we have experiment problem whit cron job in this new version, we need to know if some other experiment this and if have solution for this problem, the cron no complete and no send email confirmation, this happen before we update to the new version 3.8.1 after the update all work perfect. please if some know some about this let me know. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 18, 2008 Author Share Posted December 18, 2008 hello, for solve this problem and generate invoice and payments we need diable this Update Usage Statistics Tick this box to update automatically when the cron runs we disable and now cron job work but no udate client Update Usage Statistics 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted December 18, 2008 Share Posted December 18, 2008 sounds like your cron is timing out - so fixes would be - better connectivity from the WHMCS server to the server(s) with the clients on - change the php ini file - set an exception for yoru cron in any automated "killer" processes - put less people on each box 0 Quote Link to comment Share on other sites More sharing options...
aegisdesign Posted December 19, 2008 Share Posted December 19, 2008 Same problem here. The cron task was working fine without missing a beat for the past year until I upgraded to v3.8.1. Now it seems to hang and I've not got emails for the past few days. I've now switched off 'Update Usage Statistics' and it's working again. Did something change in this ? 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted December 19, 2008 Share Posted December 19, 2008 I am not sure if I am having the same issue or not. My cron sends an email every once and a while. Received one yesterday, but not today. My daily backup of the database ran, but not the cron task for updating stats. I don not see any errors in my access logs in regards to the crons. 0 Quote Link to comment Share on other sites More sharing options...
Gears Posted December 19, 2008 Share Posted December 19, 2008 Having issues here as well. Cron worked fine until I updated to 3.8. The cronjob does seem to run because invoices are generated, but I do not get the email every morning anymore. I downloaded a new cpanel module and will wait until next cron run to see if that fixes it. Supposedly it should. I also have another issue where the databases are not being transferred to a remote FTP anymore. The last successful delivery was on November 16. It just stopped all of a sudden. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 19, 2008 Author Share Posted December 19, 2008 all we have the same issue and is no a server issue maybe is WHMCS no close connection when finish, now i have Stats disable and cron work, i check each server we have and we no have issues in server setting, this happen when we update to New version so i no need find more problem in server Our server have exellents setting and never have issues, this problem is WHMCS. we need only a solution for this this happen before udate, after update all work why now in new version 3.8.1 no work? 0 Quote Link to comment Share on other sites More sharing options...
Gears Posted December 20, 2008 Share Posted December 20, 2008 Having issues here as well. Cron worked fine until I updated to 3.8. The cronjob does seem to run because invoices are generated, but I do not get the email every morning anymore. I downloaded a new cpanel module and will wait until next cron run to see if that fixes it. Supposedly it should. I also have another issue where the databases are not being transferred to a remote FTP anymore. The last successful delivery was on November 16. It just stopped all of a sudden. I received the cron email this morning 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted December 20, 2008 Share Posted December 20, 2008 For those on shared hosting. I posted a solution on this thread: http://forum.whmcs.com/showthread.php?t=16472 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 20, 2008 Author Share Posted December 20, 2008 hello, i do all you say and steal have the same issue? maybe is the quantity of server we have. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 21, 2008 Author Share Posted December 21, 2008 i see the problem, the problem is when try get Statistic for Reseller account if you see in your WHMCS any reseller account have statistics only normal account. verify this and you see this. 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted December 21, 2008 Share Posted December 21, 2008 Hi Zoilodiaz, For what ever reason the cron is taking longer to complete. Placing these in your .htaccess file (if a shared server) will fix this issue. If this is a dedicated server, edit the values in php.ini. max_execution_time 400 php_value memory_limit 64M I have ran my cron job 6 times and 6 times I have received my daily activity report and all appears well. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 21, 2008 Author Share Posted December 21, 2008 hello, i set the values you say and nothing i increment memory to 128M time to 1000 and nothing, i don't not what is. but for me no work. 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted December 21, 2008 Share Posted December 21, 2008 I am not sure then, anybody else have any suggestions for zoilodiaz? I would recommend not setting your memory and time out so high. Your host may not like you for it. Reduce it to 64M and 400, or just remove the lines I provided you. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 21, 2008 Author Share Posted December 21, 2008 i change to your suggestion, i test different sizes and nothing, this is one dedicated server only for rum our company page and WHMCS, after update this happen i no find the solution. WHMCS support say the same you say increment time to 1000 but nothing. 0 Quote Link to comment Share on other sites More sharing options...
zoilodiaz Posted December 22, 2008 Author Share Posted December 22, 2008 case close is resolve. 0 Quote Link to comment Share on other sites More sharing options...
aegisdesign Posted December 23, 2008 Share Posted December 23, 2008 Resolved for me too with a replacement cpanel.php file. 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted December 29, 2008 Share Posted December 29, 2008 Thanks for posting your solution aegisdesign, zoilodiaz was that the same solution? 0 Quote Link to comment Share on other sites More sharing options...
LeMarque Posted January 8, 2009 Share Posted January 8, 2009 Resolved for me too with a replacement cpanel.php file. Many thanks. I ran/forced 'Upgrade to latest version' in WHM and Voila!. I think this should be made a sticky somewhere for all the others that are having this issue. 0 Quote Link to comment Share on other sites More sharing options...
KingJ Posted January 12, 2009 Share Posted January 12, 2009 I have this problem, and turning off "Update Usage Statistics" does allow me to receive my report again. Where can I get this updated cpanel.php file aegisdesign is referring to? 0 Quote Link to comment Share on other sites More sharing options...
LeMarque Posted January 12, 2009 Share Posted January 12, 2009 In WHM >> cPanel >> Upgrade to latest version 0 Quote Link to comment Share on other sites More sharing options...
KingJ Posted January 12, 2009 Share Posted January 12, 2009 I ran that, however no files where updated. Using the CURRENT release. 0 Quote Link to comment Share on other sites More sharing options...
LeMarque Posted January 12, 2009 Share Posted January 12, 2009 hmmm... did you select 'Force a reinstall even if the system is update to date'? If so, then I'm not sure what to suggest 'cause that seemed to fix it for me 0 Quote Link to comment Share on other sites More sharing options...
KingJ Posted January 12, 2009 Share Posted January 12, 2009 No, I didn't try that. Will do now. 0 Quote Link to comment Share on other sites More sharing options...
Ros Posted February 1, 2009 Share Posted February 1, 2009 No, I didn't try that. Will do now. Did you try this and if so did it resolve the issue for you? 0 Quote Link to comment Share on other sites More sharing options...
