Marcello Ruoppolo Posted September 5, 2023 Share Posted September 5, 2023 Hello everyone, I bought a hosting company that was going bankrupt, and I need to migrate their WHMCS clients to my own WHMCS. The problem is that they were using a nulled WHMCS, while mine is a licensed version. How can I migrate without losing client data? 0 Quote Link to comment Share on other sites More sharing options...
SimpleSonic Posted September 6, 2023 Share Posted September 6, 2023 Honestly, I wouldn't want a valid production WHMCS installation anywhere near a nulled version. Depending on how many clients are being migrated, manual migration might just be the best option. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted September 6, 2023 Share Posted September 6, 2023 4 hours ago, ResellerWiz said: manual migration might just be the best option Wouldn't a lot be lost that way? You can enter their info in the new system, but they'd lose tickets, invoices and far more, no? That is, unless you know of a way to export and then import all of that per account? 0 Quote Link to comment Share on other sites More sharing options...
SimpleSonic Posted September 7, 2023 Share Posted September 7, 2023 2 hours ago, bear said: Wouldn't a lot be lost that way? You can enter their info in the new system, but they'd lose tickets, invoices and far more, no? That is, unless you know of a way to export and then import all of that per account? It would certainly be more complicated, but I’d rather deal with manually exporting/importing SQL data rather than connecting a nulled WHMCS to a legitimate production one and blindly running an import script. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted September 7, 2023 Share Posted September 7, 2023 I'm not entirely sure there's a difference in an import script vs manually creating an SQL import, unless you intend to read, review and scrub it all. An import script for single users with the ability to review before finalizing would be awesome, but I only know of the one WHMCS has that is an all or nothing. 0 Quote Link to comment Share on other sites More sharing options...
SimpleSonic Posted September 7, 2023 Share Posted September 7, 2023 1 hour ago, bear said: I'm not entirely sure there's a difference in an import script vs manually creating an SQL import, unless you intend to read, review and scrub it all. An import script for single users with the ability to review before finalizing would be awesome, but I only know of the one WHMCS has that is an all or nothing. Manually examining in the SQL data and choosing what to import would give you the control over what is being imported as opposed to allowing WHMCS' automated script to just do it all in one go. It would certainly be more time consuming, but connecting a nulled instance to a production one and using an automated import script? Nope. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted September 7, 2023 Share Posted September 7, 2023 I find it hard to think like a hacker, but I don't see what could be in user data that might cause issues. The core program, sure, but user data? I agree it would be worrisome, but I can't think of why other than the obvious. 0 Quote Link to comment Share on other sites More sharing options...
SimpleSonic Posted September 7, 2023 Share Posted September 7, 2023 22 minutes ago, bear said: I find it hard to think like a hacker, but I don't see what could be in user data that might cause issues. The core program, sure, but user data? I agree it would be worrisome, but I can't think of why other than the obvious. I'm probably just paranoid, but have seen exploits occur due to people taking things for granted, so I tend to have the 'better safe than sorry' attitude. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted September 7, 2023 Share Posted September 7, 2023 Being paranoid doesn't mean they *aren't* out to get you. 🙂 0 Quote Link to comment Share on other sites More sharing options...
lulzkiller Posted September 7, 2023 Share Posted September 7, 2023 8 hours ago, bear said: Being paranoid doesn't mean they *aren't* out to get you. 🙂 Way to make one less paranoid hahaha xD 0 Quote Link to comment Share on other sites More sharing options...
megox58823 Posted October 23, 2023 Share Posted October 23, 2023 No idea why that would be missing. It's under "System Information " on mine. Have you started using the subscription? Maybe that does what you're seeing (though I don't see why it would). 0 Quote Link to comment Share on other sites More sharing options...
