Cron's DivisionByZeroError Problem
wpmattuk
As the title says, Cron has encountered a DivisionByZeroError error for 2 days on the run now. Invoices aren't being generated, along with any other processes relying on Cron.
The full email content is (have changed certain path elements) in the attached; as I couldn't include this text in the post.
Thanks anyone that can help!
Simply put during cron WHMCS causes the fatal error as it is trying to divide a null variable by a number. Probably there is a null amount somewhere in tblinvoiceitems or tblinvoices. No one apart from WHMCS staff can help you fixing this error as they obfuscate PHP files so that you never know what is the exact line that caused the error.
  • WHMCS Product Manager
Hi @thisismatt,
Can you please confirm whether you're running v8.6.1?
We addressed an identical error in the latest release for PHP 8.1 environments:
Quote
CORE-18266 - Prevent error in PHP 8.1 for invoices generated with 100% discount
https://docs.whmcs.com/Changelog:WHMCS_V8.6.1
Hi @thisismatt.
Glad to hear the issue is now resolved.
With regards to the auto-updating issue; what error did you experience, please?
Some of the most common errors are detailed at:
1 hour ago, WHMCS John said:
Hi @thisismatt,
The entries in the tblupdatelog table from the time of performing the-update may provide some indication of the root cause of the problem.
Please do share them here for us to review.
I've got the dump of the table, but as it contains paths/filenames unique to me I'd rather not add it here, how can I share with you guys privately?
