How to get WHMCS System URL inside module?
weelow
I was looking for a fast way to do this, and came across the below thread, which is closed now and the original poster did not mention how he did it using global $CONFIG.  I am going to describe how it can be done with a way other than directly accessing the database.
In the below URL it describes how you can get the base url where WHMCS is installed
Spoiler
\WHMCS\Utility\Environment\WebHelper::getBaseUrl()
Refrence: https://docs.whmcs.com/WHMCS_Base_URL_Template_Variable
This displays retrives the base url only so if this is the link to your whmcs https://www.yourdomain.com/whmcfolder/ this function will display as follows in html "/whmcsfolder"
to get the complete url to display add the following:
Spoiler
$protocol = $_SERVER['HTTPS'] == 'on' ? 'https' : 'http';
$baseurl = \WHMCS\Utility\Environment\WebHelper::getBaseUrl();
$url = $protocol.'://'.$_SERVER['HTTP_HOST'].$baseurl;
The above $url will display as follows https://www.yourdomain.com/whmcfolder/
I hope this is useful for anyone. Additions are always welcome of course.
Have a good day
I find easier and more reliable to select it from database with:
SELECT value FROM tblconfiguration WHERE setting = 'SystemURL' LIMIT 1
With HTTP_HOST in fact you are dependent on http request header that can be manipulated while SERVER_NAME is not always available (it depends on server configuration). In conclusion I always use the one in database especially for licensing scripts 😋
Is there a faster way to get it though, i mean it should be already loaded from the database why load it again.
I am trying to find if the global $CONFIG variable can do such thing but i cant find any information about it anywhere.
global $CONFIG;
$URL = $CONFIG['SystemURL'];
i'd go along with Kian and get the value from the database, either using Capsule as per your linked thread or using the model.
use WHMCS\Config\Setting;
$url = Setting::getValue('SystemURL');
