snake Posted September 28, 2019 Share Posted September 28, 2019 I am suddenly no longer able to make changes in general settings, I get a 403 forbidden when I click save. This was working fine a couple of days ago, the only thing that has changed is that I updated from 7.8.2 to 7.8.3 using the auto updater, so I assume this is the cause. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted September 28, 2019 Share Posted September 28, 2019 8 hours ago, snake said: I am suddenly no longer able to make changes in general settings, I get a 403 forbidden when I click save. any clues from the cpanel / server logs ? 8 hours ago, snake said: This was working fine a couple of days ago, the only thing that has changed is that I updated from 7.8.2 to 7.8.3 using the auto updater, so I assume this is the cause. can you get hold of the 7.8.3 incremental patch and upload that via FTP ? 0 Quote Link to comment Share on other sites More sharing options...
snake Posted October 3, 2019 Author Share Posted October 3, 2019 This is in the cpanel errors log 2019-10-03 23:37:37.534019 [INFO] [35686] [162.158.62.72:46904] File not found [/home/foodbooking/public_html/403.shtml] 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted October 4, 2019 Share Posted October 4, 2019 I see you opened another thread... 0 Quote Link to comment Share on other sites More sharing options...
Hosterline Posted October 6, 2019 Share Posted October 6, 2019 On 4/10/2019 at 9:37 PM, brian! said: I'm facing the same problem in General Settings Option When i click on Save Changes then it return with the 403 Error 0 Quote Link to comment Share on other sites More sharing options...
reptilehosting Posted November 13, 2019 Share Posted November 13, 2019 i have the same error,how could i fix this? 0 Quote Link to comment Share on other sites More sharing options...
snake Posted November 13, 2019 Author Share Posted November 13, 2019 it was caused by mod_security (WAF) blocking the requests. If you are on shared hosting, you will need to contact your host to fix it. If it is your own server, check your WAF logs. 0 Quote Link to comment Share on other sites More sharing options...
