Nameserver field validation problem
Logman
 On our VPS order form I'm getting this error on the first step:
Quote
Please correct the following errors before continuing:
The nameserver prefix is invalid.
This is when a client inputs:
ns1.domain.com
ns2.domain.com
If they simply enter ns1 and ns2 the order proceeds just fine. In the past we've been able to enter ns1.domain.com and ns2.domain.com and that seems pretty natural. This is a problem that needs a solution. For now I'm adding text in configureproduct.tpl.
Edited by WHMCS ChrisD
Corrected issue with quote
14 minutes ago, Logman said:
We use the Control Theme and use one of their order forms. It does happen with Standard Cart though. I don't have Six installed, must have removed it in a clean up. Can it be downloaded anywhere?
Hey @Logman
downloads.whmcs.com is the place to get the full release files from if you are using a version older than v7.3.1 then support can provide them
  • 4 years later...
Edit the file at /templates/orderforms/standard_cart/configureproduct.tpl
Find the line:
<input type="text" name="ns1prefix" class="form-control" id="inputNs1prefix" value="{$server.ns1prefix}" placeholder="ns1">
Replace the line with:
<input type="text" name="ns1prefix" class="form-control" id="inputNs1prefix" value="ns1">
Find the line:
<input type="text" name="ns2prefix" class="form-control" id="inputNs2prefix" value="{$server.ns2prefix}" placeholder="ns2">
<input type="text" name="ns2prefix" class="form-control" id="inputNs2prefix" value="ns2">
