wp4all Posted February 11, 2018 Share Posted February 11, 2018 Hi @ all, have somebody an idea where I can find the location to translate the error message in the knowledge database ? Find the screen here http://prntscr.com/id9a6u Greetings Chris Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted February 11, 2018 Share Posted February 11, 2018 Hi Chris, Are you referring to the search wording? These are the language overrides that you can you can use. $_LANG['kbquestionsearchere'] = "Have a question? Start your search here."; $_LANG['kbsearchexplain'] = "Have a question? Start your search here."; $_LANG['clientHomeSearchKb'] = "Enter a question here to search our knowledgebase for answers..."; Link to comment Share on other sites More sharing options...
brian! Posted February 12, 2018 Share Posted February 12, 2018 Chris (both of you!), 20 hours ago, wp4all said: have somebody an idea where I can find the location to translate the error message in the knowledge database ? 16 hours ago, WHMCS ChrisD said: Are you referring to the search wording? These are the language overrides that you can you can use. using overrides wouldn't initially help - because the string is hard-coded in English in the knowledgebase.tpl template. <input type="text" id="inputKnowledgebaseSearch" name="search" class="form-control" placeholder="What can we help you with?" /> you would need to edit the template and replace that string with an override language string (e.g one of the one's suggested by @WHMCS ChrisD)... <input type="text" id="inputKnowledgebaseSearch" name="search" class="form-control" placeholder="{$LANG.kbquestionsearchere}" /> then if you need to edit that string for any language, just use the Language Overrides process to change them. also, make a note of the above change, because unless WHMCS notice that the string is hard-coded in the template and fix it themselves, you will need to edit the template again after a WHMCS update. 1 Link to comment Share on other sites More sharing options...
