Need help to understand the header & footer options within invoicepdf.tpl
itoverblik
To WHMCS forum members
I am trying to understand the header & footer options within the invoicepdf.tpl file.
As mentioned in KB http://docs.whmcs.com/PDF_Invoice_Customisation it should be straight forward.
But when I have created the invoicepdffooter.tpl file and added standard PHP or HTML code within the PDF file is corrupt.
What syntax should I use and where do I see some examples so that I can get an idea on how to handle it?
Thanks in advance :)
- Tim
  • WHMCS Product Manager
Can you clarify exactly how the file is corrupt when you create it? Are you getting an actual corruption error, or is is just not being displayed as expected?
Perhaps post a screenshot and your customised template files so we can review?
Hi John
Thanks for your reply, I didn't see your reply due to missing notifications.
I will get back to you with screenshots.
What I meant with corrupt PDF is that it get's created but when I tries to open the PDF file Adobe Reader drops an error saying the file is corrupt.
- Tim
Hi Brian
Just what I needed, it works fine with the page of as mentioned in the other forum post :)
Now I will try to get it working with the stuff I wanted to use with these files, currently unknown and forgotten, it might get back to me, LOL.
Another question Brian.
How do add a code to the invoicepdf.tpl so that it make a page break to be able to add our business terms on a new page within the PDF file?
- Tim
cheat - and attach it as a separate PDF to the invoice email template! :-P
but if you really want to add the terms to the same PDF, you could use the following code...
$pdf->AddPage();
$pdf->setPage($pdf->getPage());
$ourterms = 'The quick brown fox jumped over the lazy dog.';
$pdf->writeHTML($ourterms, true, false, false, false, '');
the first two lines are the important ones - after that, it's just a case of choosing how/what to output... e.g using HTML, a HTML table... or using the Cell/Multicell options.
e.g if you copy/paste the WHMCS terms, and added some HTML coding to the output, the next page after the invoice would start...
  • 3 years later...
