malesela Posted January 24, 2017 Share Posted January 24, 2017 I'm new on the forum and WHMCS product and need help. Installed the product linked it with WHMCS - all working perfectly. Issue: WHMCS products are not linking to WHM packages. From WHMCS, I can see clients (with pending status), I can see orders (with pending status). From Utilities Module Queue, I see the following error messages: "Service not assigned to a module" and "Product attribute Package Name "webhoste_Test" not found on server". From Setup Products/services >> Products/services >> edit >> module setting, module name "Cpanel" is selected. There is now "WHM" module name. On the WHM Package Name, I don't see products I created in the WHM Package. From Products/services servers >> edit, all looks ok and connection test was successful Under utilities, Cpanel/whm import >> get account list, domain in the whm account show up - confirmation that WHM and WHMCS are linked. WHERE AM I GETTING THINGS WRONG? 0 Quote Link to comment Share on other sites More sharing options...
GioAbove5K Posted March 22, 2017 Share Posted March 22, 2017 I'm having the same issue, have you found a solution yet? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted March 24, 2017 WHMCS Product Manager Share Posted March 24, 2017 Hi, In order to see the commands being sent/received between WHMCS and the module, the Utilities > Logs > Module debug Log tool can be used Please enable it, reproduce the problem, disable it again and then copy the data into this ticket reply for us to review. More detailed instructions are published at http://docs.whmcs.com/Troubleshooting_Module_Problems N.B. Please take care to remove any sensitive data before posting it publicly here. 0 Quote Link to comment Share on other sites More sharing options...
atlakeem Posted March 28, 2017 Share Posted March 28, 2017 any update to this? i'm having the same problem, I did not have this problem with Version 5. I upgraded to 7.1.1, and a new client signed on with no issues back in January. Now I am showing the same error 0 Quote Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted March 28, 2017 Share Posted March 28, 2017 any update to this? i'm having the same problem, I did not have this problem with Version 5. I upgraded to 7.1.1, and a new client signed on with no issues back in January. Now I am showing the same error What errors are showing in your Module Log? 0 Quote Link to comment Share on other sites More sharing options...
