General Settings page fails to render after upgrade to 6.2
SealIsland
After upgrading to 6.2 The general settings page no longer renders properly. Any suggestions?
a couple of things to quickly check...
1. are you using an admin template that is no longer supported in v6 - e.g "Original" ?
http://docs.whmcs.com/Version_6.0_Release_Notes#Admin_Area_Templates
2. if not, emtpy the template cache and see if that fixes the issue.
upload the upgrade again - it might be caused by a missing or corrupt upload the first time.
  • 1 month later...
Sorry about the gap, I reverted to the old version to cure the problem, but it has come back with the new upgrade. When I enable the error log using the config.php enty I now get
Fatal error: Only variables can be passed by reference in /home/sealisl2/public_html/clients/vendor/phpmailer/phpmailer/class.phpmailer.php on line 1159
I tried changing the template then upgrading again, and I tried removing the reseller modes files I could find, but problem persists.
  • WHMCS Product Manager
This file is not encoded, so looking around the line from the error message:
  • Please make sure that the idn_to_ascii and mb_convert_encoding PHP functions are compiled.
  • Also check the tblconfiguration.Charset and tblconfiguration.Email fields contain valid values. The default are utf-8 and noreply@mycompany.com respectively.
