Changing status to ACTIVE after unsuspending with upgrading. Help pls
GrayHunter
Just discovered a vital issue:
The client get the product for free trial (a free product). After several days his account was blocked by a module ("Free Trials") while cron job and an invoice for upgrading was created (by the same module) - see the logs pls. Than the client paid the invoice and the product was changed (upgraded), nice.
But the status of the product was still SUSPENDED, not ACTIVE.
So the client paid but his account was not unsuspended - it was stayed blocked.
Smth should automatically change the status to ACTIVE as clients will become angry - they pay but get nothing.
How can I fix this? :?:
Regards, Eugene.
As brian said it's very possible that it's an issue related to the Server Module that you are using. Maybe it's due to some if() that is going wrong, a missing expected value, timeout, problems in handling $result (I bet 1 cent. on this :-P) etc.
If you can't contact the author of the module, can you at least access to source code?
