wezem Posted April 17, 2014 Share Posted April 17, 2014 Hi, I have a problem in the "product details", all the links and buttons are visible but not working. For example, the plesk login button is visible but not bring to the login page, the change password buttons (save and cancel) are visible but not working and the link to the domain is visible but not working! Can you give me a hand? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted April 18, 2014 WHMCS Product Manager Share Posted April 18, 2014 Hi, Do you have a custom template perchance? Does the issue still happen with the stock tempaltes (default, portal, classic)? 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted April 19, 2014 Share Posted April 19, 2014 as John said, if you're using a custom template, there may be a jquery conflict (perhaps being called twice) in it. 0 Quote Link to comment Share on other sites More sharing options...
