amirhkh Posted April 6, 2014 Share Posted April 6, 2014 Hi i installed WHMCS on windows server 2012 , i installed ioncube and all other Requirements the installatin was successfully with this message : Installation Complete with no error or alert , i renamed the install folder but when i want to open /admin or / , the system message is : Down for Maintenance One or more required files are missing. If an install or upgrade is not currently in progress, please contact the system administrator. 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted April 6, 2014 Share Posted April 6, 2014 Upload all files again. Seems like some files wasn't uploaded completely. 0 Quote Link to comment Share on other sites More sharing options...
amirhkh Posted April 6, 2014 Author Share Posted April 6, 2014 thanks for your reply i checked the files , all files are ok but the error message exist yet 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted April 8, 2014 WHMCS Product Manager Share Posted April 8, 2014 Hi, If all the WHMCS files definitely exist on your server, this means that the script cannot read them. For Windows, realpath requires execute permission on all directories (list file contents). 0 Quote Link to comment Share on other sites More sharing options...
milesibastos Posted April 9, 2014 Share Posted April 9, 2014 I'm having the same probolema on Amazon AWS Ubuntu Server 12.04 LTS (PV) - ami-e3aa09fe (32-bit). Sometimes works and sometimes not. images on attachments. 0 Quote Link to comment Share on other sites More sharing options...
lscreative Posted April 9, 2014 Share Posted April 9, 2014 I'm having the same error! Does anyone have a fix? 0 Quote Link to comment Share on other sites More sharing options...
MrRadic Posted June 30, 2015 Share Posted June 30, 2015 For PHP RealPath() the parent folder (above the WHMCS root folder) must also have read permissions. Set those permissions and everything will magically start working. Support had no clue about this, but it seems to be a common issue. http://forums.iis.net/p/1153823/1887716.aspx 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted July 1, 2015 WHMCS Product Manager Share Posted July 1, 2015 Hi, This is something we have documented internally. For the purposes of feedback and further improving the quality of our support, I'd much appreciate if you would be so kind as to PM the Ticket ID in question to me. 0 Quote Link to comment Share on other sites More sharing options...
