DennisHermannsen Posted June 29, 2013 Share Posted June 29, 2013 Hello, guys I found something weird on our site today; when accessing submitticket.php, it looks like there's supposed to be a fifth support department, but there's not showing more than 4 departments - and we only have four, so that's understandable. After looking in the .css files for some time, I went ahead and took a look at it with the default theme - and it's the exact same: Anyone got a clue on what's causing this? 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted June 30, 2013 Author Share Posted June 30, 2013 Anyone got an idea what the problem could be? 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted July 1, 2013 Author Share Posted July 1, 2013 Can someone help? 0 Quote Link to comment Share on other sites More sharing options...
jclarke Posted July 1, 2013 Share Posted July 1, 2013 It's possible what you have added for the livechat support is causing some issues with the HTML or CSS. It is hard to say what is wrong by just looking at the screenshot and not the actual html. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 1, 2013 Share Posted July 1, 2013 jclarke's idea about livechat is probably worth investigating - when I saw the image, I thought there might be some special character in one of the headings that is changing the formatting in some way... but as previously stated, without seeing the html code, there's no real chance of knowing for sure. if you don't want to give the URL, then your best bet may be to submit a ticket to WHMCS. 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted July 2, 2013 Author Share Posted July 2, 2013 (edited) Well, there's not made any changes to the WHMCS default theme (the live chat code is implemented in the source code i think) so if that's the case (that's the live chat is causing it), I'd be very surprised... Edit: I don't think that was the case. I just removed this from header.tpl {if $livehelpjs}{$livehelpjs} {/if} It was still the same. Edited July 2, 2013 by DennisMidjord 0 Quote Link to comment Share on other sites More sharing options...
jclarke Posted July 2, 2013 Share Posted July 2, 2013 If you could provide a link to this we can offer you more help. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted July 2, 2013 Share Posted July 2, 2013 If you could provide a link to this we can offer you more help. you could remove your own domain name from the source code if you wish and post it here - but I don't think we can help further without seeing either the code or, better still, a link to the site. 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted July 2, 2013 Author Share Posted July 2, 2013 http://game-desk.net/submitticket.php Don't mind the colors and the baaaaad template. We're working on another template 0 Quote Link to comment Share on other sites More sharing options...
jclarke Posted July 2, 2013 Share Posted July 2, 2013 Try changing <div class="center80"> to <div class="center95"> 0 Quote Link to comment Share on other sites More sharing options...
DennisHermannsen Posted July 2, 2013 Author Share Posted July 2, 2013 (edited) Worked perfectly... I guess one of the descriptions was too long? Edit: Yep... The description under "Support" was just a bit too long. Thanks for helping, mate. Edited July 2, 2013 by DennisMidjord 0 Quote Link to comment Share on other sites More sharing options...
