snake Posted November 12, 2012 Share Posted November 12, 2012 When user tries to save/update contact details, they get the following error. registered_for:Not Specified:Required value not specified There is no field called "registered for" and all the displayed fields are filled in. Also the bulk management options do not work, clicking any of the buttons does nothing at all. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted November 14, 2012 WHMCS Product Manager Share Posted November 14, 2012 Hi, Which domain registrar are you using? Do you see any missing values hen you enable the module debug log? http://docs.whmcs.com/Troubleshooting_Module_Problems 0 Quote Link to comment Share on other sites More sharing options...
snake Posted November 14, 2012 Author Share Posted November 14, 2012 we use ENOM. I checked the debug log and "registered_for" is indeed being sent with no value. 0 Quote Link to comment Share on other sites More sharing options...
snake Posted November 15, 2012 Author Share Posted November 15, 2012 OK I found the cause for that one, the "Registrant Name" must be filled in and it must also EXACTLY match the current WHOIS or it will fail with a different error as your not allowed to change this info. It seems some better error handling is required as WHMCS really doesn't tell you anything remotely useful when things fail, it just seems to show you the error from the ENOM API. So with this info I managed to get the "registrant to update", but the ADMIN and TECH contacts will not update. If I change to "Use Existing Contact" and click save, or if I choose "Use Following Details" and fill in the form, nothing gets changed, the details do not get updated, and the page reloads with the old details still intact. This seems to be a bug ? 0 Quote Link to comment Share on other sites More sharing options...
