Tr3ck Posted July 27, 2012 Share Posted July 27, 2012 Hello, I have this message on many of my clients: "Imported using WHM Import Script - Payment Method, Pricing, Billing Cycle & Next Due Date may be incorrect" and each cron job, they are all deleted from WHM (and finished on WHMCS) .. 0 Quote Link to comment Share on other sites More sharing options...
easyhosting Posted July 28, 2012 Share Posted July 28, 2012 if i get you right, all you clients accounts are being terminated from your WHM when the WHMCS cron runs. this is most likely the due date in WHMCS for the clients accounts are not set correctly. This needs to be a date in the future. 0 Quote Link to comment Share on other sites More sharing options...
Raven Posted July 29, 2012 Share Posted July 29, 2012 if i get you right, all you clients accounts are being terminated from your WHM when the WHMCS cron runs. this is most likely the due date in WHMCS for the clients accounts are not set correctly. This needs to be a date in the future. I agree with easyhosting sounds like the due date. "Imported using WHM Import Script - Payment Method, Pricing, Billing Cycle & Next Due Date may be incorrect" is a kinda kick in the butt to check it and make sure all is ok 0 Quote Link to comment Share on other sites More sharing options...
Tr3ck Posted July 29, 2012 Author Share Posted July 29, 2012 Boh .. I don't think .. Look that : /http://img138.imageshack.us/img138/8769/preuvee.png 0 Quote Link to comment Share on other sites More sharing options...
Tr3ck Posted August 3, 2012 Author Share Posted August 3, 2012 I solved the problem, I have no message. but accounts continued to be deleted .. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted August 13, 2012 WHMCS Product Manager Share Posted August 13, 2012 Hi, Please review the entries you see under Utilities > Logs > Activity Log at the time these accounts are terminated as that should shed some light on the matter. With a Next Due Date in the future the most likely cause is you've configured your products with auto-terminate/fixed term: http://docs.whmcs.com/Products_and_Services#Pricing_Tab 0 Quote Link to comment Share on other sites More sharing options...
