SteveV Posted July 11, 2012 Share Posted July 11, 2012 - when an order is accepted, expiry date for domain is not changed from 00/00/0000 to correct date and domain status remains as 'pending' 0 Quote Link to comment Share on other sites More sharing options...
arhost Posted July 11, 2012 Share Posted July 11, 2012 I can also confirm this. The domain registration remains pending and the domain does not get registered. You have to go to domain tab and manually click on register to register the domain name. 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 11, 2012 Share Posted July 11, 2012 does the expiry date not get update when the cron job runs?? the next due date should be eg 2013, expiry 0000 etc then it updates when the cron runs.. thats how it worked on ours 0 Quote Link to comment Share on other sites More sharing options...
SteveV Posted July 11, 2012 Author Share Posted July 11, 2012 @lance - no, the expiry date has always been updated immediately after accepting an order for us, before 5.1.2 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 11, 2012 Share Posted July 11, 2012 never has for us... thats always updated on the cron run, even though now the cron has run the expiry date has not updated, possibly due to only 20-30 domains being processed when the cron runs ? 0 Quote Link to comment Share on other sites More sharing options...
staralgerie Posted July 11, 2012 Share Posted July 11, 2012 I can also confirm this. The domain registration remains pending and the domain does not get registered.You have to go to domain tab and manually click on register to register the domain name. Greeetings, I can also confirm this bug, Regards 0 Quote Link to comment Share on other sites More sharing options...
netmotiv8 Posted July 11, 2012 Share Posted July 11, 2012 We are seeing this also 0 Quote Link to comment Share on other sites More sharing options...
mazaamahesh Posted July 11, 2012 Share Posted July 11, 2012 I am having the same issue 0 Quote Link to comment Share on other sites More sharing options...
HostinPK Posted July 11, 2012 Share Posted July 11, 2012 Same here. We can also confirm this bug. We had to regd 10 domains manually so far. Actually, domain is not regd through stargate or NEO module. Matt suggest us something. 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 11, 2012 Share Posted July 11, 2012 (edited) quick update, we sold a few domains today, the coms etc are updating and going active straight away and expiry dates are updated, the UK domains are though staying pending and 0000 as above users. All domains have registered with the respective registrar Edited July 11, 2012 by lance 0 Quote Link to comment Share on other sites More sharing options...
insider1 Posted July 11, 2012 Share Posted July 11, 2012 We have same problem. We use Resellerclub and on order accepting domain is not registered and stays pending. Then when registering domain from domain details page sometimes getting error: "Error: Error obtaining customer id ". After retrying domain is registered at Resellerclub, but in WHMCS it stays in pending state and expiration date is updated. So after semi-manual registration we have also to update domain status and expiration date in WHMCS manually. 0 Quote Link to comment Share on other sites More sharing options...
sco Posted July 12, 2012 Share Posted July 12, 2012 yes . exactly the same as Lance here 0 Quote Link to comment Share on other sites More sharing options...
serverfreak Posted July 12, 2012 Share Posted July 12, 2012 same problem with renewed domain. status doesn't update and expiry date doesn't add additional year. 0 Quote Link to comment Share on other sites More sharing options...
Si Posted July 13, 2012 Share Posted July 13, 2012 This thread should be merged: http://forum.whmcs.com/showthread.php?51102 I thought I was alone in this. Major nightmare this. Can't figure out this cron sync only doing 50 domains at a time either. 0 Quote Link to comment Share on other sites More sharing options...
SteveV Posted July 13, 2012 Author Share Posted July 13, 2012 If these threads are merged, I'd like to point out that our problem is with domains (like co.za and .org.za) using "Email" as the registrar. We register .com etc manually. 0 Quote Link to comment Share on other sites More sharing options...
Si Posted July 13, 2012 Share Posted July 13, 2012 Fair enough. The issue then on the thread I started is nominet (UK) related only. There are some cross-over issues that seem to be related though. I've reverted back to using the old individual nominetsync.php script but registrations are still failing. 0 Quote Link to comment Share on other sites More sharing options...
lfrauseo Posted July 14, 2012 Share Posted July 14, 2012 Hi. I confirm too Today I receive 2 order for a new domains. This are the first new order before the upgrade to 5.1.2 1) When I accept the 2 orden by ckeck, and press de accept botton, both order are accepted, but not are send the registration command to ENOM register. 2) Both order are for 1 new domain with ID Protecion And DNS management 3) I try again change the order status a Pending, and choose ENOM Registran. 4) Then I try again accept on one of the order, the same issue. Accept the order bur not make the register domain in ENOM. 5) If you see my log, not show that WHMCS send the register command to ENOM. 0 Quote Link to comment Share on other sites More sharing options...
JoshDargie Posted July 16, 2012 Share Posted July 16, 2012 Hi. I confirm too Today I receive 2 order for a new domains. This are the first new order before the upgrade to 5.1.2 1) When I accept the 2 orden by ckeck, and press de accept botton, both order are accepted, but not are send the registration command to ENOM register. 2) Both order are for 1 new domain with ID Protecion And DNS management 3) I try again change the order status a Pending, and choose ENOM Registran. 4) Then I try again accept on one of the order, the same issue. Accept the order bur not make the register domain in ENOM. 5) If you see my log, not show that WHMCS send the register command to ENOM. Hello, I've noticed this issue with my own install, all our domains go through eNom and when we process the activation of the hosting account and domain purchase it doesn't change from "pending" and instead we must manually go to the "Domains" customer window and click the Register or Transfer button to properly start this. How did this kind of crap get ignored by WHMCS, or better yet how did they manage to break a perfectly working system? 0 Quote Link to comment Share on other sites More sharing options...
SteveV Posted July 16, 2012 Author Share Posted July 16, 2012 I agree with you that this is unacceptable. We process large numbers of domain orders every day, and this has creating an unnecessary workload which we could well do without. How did this get through beta testing? Or are we all the beta testers now? 0 Quote Link to comment Share on other sites More sharing options...
sol2010 Posted July 16, 2012 Share Posted July 16, 2012 A patch has been posted here - try at your own risk! http://forum.whmcs.com/showthread.php?51586-Domain-Registrations-Renewals-Failing WHMCS staff does seem remarkably quiet on this - but they have 500 + tickets (probably) waiting on a response! I guess that's why they are hiring support staff !! 0 Quote Link to comment Share on other sites More sharing options...
SteveV Posted July 17, 2012 Author Share Posted July 17, 2012 Unfortunately, that patch does not fix the problem. There are now at least 7 bugs/broken functionality which are making things very difficult for us and frustrating our clients. 0 Quote Link to comment Share on other sites More sharing options...
