"Pausing" products
Locutus
Hello!
Say I have a client who's renting a virtual machine, and who wishes to "pause" using the server for some months, but not terminate it.
What would be the proper state and procedure for the product to "deliberately suspend" it for some time (only talking about WHMCS handling here, not provisioning API), and later restart it?
You mean I should terminate the existing product and create a new one once the client continues using it? (I'm only talking about management in WHMCS, not what happens to the actual virtual machine...)
There's no "paused" state reflected in WHMCS?
Speaking of which... Can you (or someone :) ) maybe tell me what is the exact meaning, as in "intended connotation", and "technical implementation/treatment", of the two product states "terminated" and "cancelled"?
Edited by Locutus
  • WHMCS Support Manager
Functionality wise there's no difference between the two statuses, but Cancelled is used when a client placed a cancellation request and terminated is used when it's terminated automatically due to non payment. Both stop the client from being invoiced.
Thanks John+Othello!
Would you suggest that in my case, I could set the product to "Cancelled" (since the client effectively did cancel it, if only temporarily), and when he decides to continue using it, I would set it to "Active" again and modify the "next due date" appropriately?
I suppose there is no "pause request" or "suspension request", and consequently a "resume request" (in addition to the cancellation request) available to the client from the frontend? :) Might be an idea for a future new feature.
This may be none of my business, but has a client actually asked you for this? Personally I would not offer such a service as pausing billing on something which you won't really be able to use anyway in the meantime, and nor would I expect to receive such a service if I was the customer. If you want a service you pay for it, if you don't want to pay for it you don't get it.
Of course that's up to you but seems a strange concept to me.
I agree with you
