steven-one Posted May 30, 2011 Share Posted May 30, 2011 Hello, I'm searching for customizations or settings that will speed up WHMCS. I'm from the frustration generation and I hate waiting 1 second for a new page. Even if it occurs once in an hour. I use pagespeed plugin for my server to speed things up a little, but other than that I don't know how to speed up things. Are the caching modules or settings for WHMCS? Thanks for your reply! 0 Quote Link to comment Share on other sites More sharing options...
robb3369 Posted May 30, 2011 Share Posted May 30, 2011 What kind of hosting/server is your WHMCS running on? 0 Quote Link to comment Share on other sites More sharing options...
steven-one Posted May 30, 2011 Author Share Posted May 30, 2011 Very delicate one think Xeon Quad processor 2048MB RAM memory Processor Name Intel® Xeon® CPU L5630 @ 2.13GHz Processor Speed (MHz) 333.353 Server info says there are 16 of those. 0 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted May 30, 2011 Share Posted May 30, 2011 The only speed improvement you can make in WHMCS, that I know of, is to disable the client drop down list. Other than that look at installing Zend Accelerator of Memcache or something like that. Also look at using nginx instead of Apache 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted May 31, 2011 WHMCS Product Manager Share Posted May 31, 2011 Yup there's not much you can do on the software side of things; it's fully optimised already 0 Quote Link to comment Share on other sites More sharing options...
Roger Posted May 31, 2011 Share Posted May 31, 2011 Hey guys... I know this is off topic. Based on SoftDux suggestion of using nginx . Is anyone here using nginx w/cPanel and WHMCS? I apologize for being off topic. Please respond in this http://forum.whmcs.com/showthread.php?p=188843#post188843 topic. Thanks folks, -Roger 0 Quote Link to comment Share on other sites More sharing options...
msaunders Posted May 31, 2011 Share Posted May 31, 2011 Very delicate one think Xeon Quad processor 2048MB RAM memory Processor Name Intel® Xeon® CPU L5630 @ 2.13GHz Processor Speed (MHz) 333.353 Server info says there are 16 of those. More ram would maybe help ? 0 Quote Link to comment Share on other sites More sharing options...
steven-one Posted June 8, 2011 Author Share Posted June 8, 2011 More ram would maybe help ? I don't think that would help. I use only 1GB of the 2GB. More RAM would mean I have more RAM not being used. Am I right? 0 Quote Link to comment Share on other sites More sharing options...
Daniel Posted June 8, 2011 Share Posted June 8, 2011 You'd likely get better performance by optimising Apache/MySQL than modifying WHMCS 0 Quote Link to comment Share on other sites More sharing options...
GORF Posted June 11, 2011 Share Posted June 11, 2011 Very delicate one think Xeon Quad processor 2048MB RAM memory Processor Name Intel® Xeon® CPU L5630 @ 2.13GHz Processor Speed (MHz) 333.353 Server info says there are 16 of those. Is this the same box your customers are hosted on? 0 Quote Link to comment Share on other sites More sharing options...
nexthost Posted June 13, 2011 Share Posted June 13, 2011 It really depends what your cpu/ram load is, paste some stats on what is going on, I would also optimize apache, mysql and a few other things, could help out, but 1 second load times, how much quicker do you want it to get? 0 Quote Link to comment Share on other sites More sharing options...
ereemst Posted October 30, 2024 Share Posted October 30, 2024 Hello all, I have a client that has on his account about 220 domain names, and about 100 other services registered on WHMCS. When he logs in it takes over 3-5 MINUTES to load his invoice. domain or services tab. It on a VPS with 32GB and 8 Core with no StealCPU, running apache with php 8.1 and 2 add ons 1 for OpenProvider and one for PAX8 Tested without and with them loaded and checked Logs etc. most normal clients with 1-5 domain names and hosting packages are fast. Please advice. 0 Quote Link to comment Share on other sites More sharing options...
