mikelegg Posted March 13, 2011 Share Posted March 13, 2011 I've just noticed that the Domain Checker is saying all .BE domains are unavailable even when they are actually available. When I click the WHOIS link, it also reports an error, which probably explains why the availability results are wrong. WHOIS Results for mytestexample.be % .be Domain Availability Server 2.0 % % (c) dns.be 2001-2004 (http://www.dns.be) % %% RC = -7 % Invalid pattern I've looked at the .be line in /includes/whoisservers.php and it seems to be inline with what is stated here about checking availability http://www.dns.be/en/home.php?n=102 Is anyone else having problems with .BE availability checking? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted March 14, 2011 WHMCS Product Manager Share Posted March 14, 2011 Which version of WHMCS are you running, do you have the .be whois server listed in /includes/whoisservers.php? 0 Quote Link to comment Share on other sites More sharing options...
mikelegg Posted March 15, 2011 Author Share Posted March 15, 2011 Hi John I'm running 4.4.2 and the line for .be in /includes/whoisservers.php is .be|whois.dns.be:4343|NOTLD-Status: FREE|get 1.0 0 Quote Link to comment Share on other sites More sharing options...
subran Posted March 15, 2011 Share Posted March 15, 2011 (edited) I had the same problem for .be domainnames since I changed the WHMCS SSL System URL from blank to my https:// This problem only occured with .be domainnames When I put the WHMCS SSL System URL again to blank; the whois on .be domainnames works again... The problem was that I had my WHMCS script on both my private_html and public_html directory Now I only use my public_html directory and it works I found how to only use public_html with ssl here http://www.directadmin.com/forum/showthread.php?t=29793 Edited March 15, 2011 by subran 0 Quote Link to comment Share on other sites More sharing options...
mikelegg Posted March 16, 2011 Author Share Posted March 16, 2011 My servers don't have an alternate directory for secure files, everything is stored in public_html. Even if I type in the http:// address to my domain checker it reloads the page as https:// Is there a setting that controls this behaviour in WHMCS? 0 Quote Link to comment Share on other sites More sharing options...
allenb Posted March 16, 2011 Share Posted March 16, 2011 Yes, Admin > General Settings > WHMCS System URL Admin > General Settings > WHMCS SSL System URL *blank no url* 0 Quote Link to comment Share on other sites More sharing options...
mikelegg Posted March 16, 2011 Author Share Posted March 16, 2011 Thanks for that. I don't really want to turn off https access for the whole of the site though - just the domain checker. 0 Quote Link to comment Share on other sites More sharing options...
allenb Posted March 16, 2011 Share Posted March 16, 2011 Do you want auto https:// site? Build or edit .htaccess RewriteEngine On RewriteCond %{SERVER_PORT} 80 RewriteRule ^(.*)$ https://Your_Url_here_to_whmcs/$1 [R,L] Replace Your_Url_here_to_whmcs with yourdomain/clients or clients.yourdomain 0 Quote Link to comment Share on other sites More sharing options...
mikelegg Posted March 16, 2011 Author Share Posted March 16, 2011 Thanks for that. If there's no fix for the actual .be whois problem, I'll use your suggestion. 0 Quote Link to comment Share on other sites More sharing options...
