Using Conversion Tracking
DimaK
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
This is a PITA.... But....
I *think* I've got it working correctly. I have it working for a $0.00 item, but there are a few tweaks that I had to make.
First, you *cannot* auto-redirect the user to either the invoice or gateway.
Your tracking code may fire *before* the user pays. If a user pays with PayPal they never go (back) to the order complete screen. I don't know about others.
My code ended up having to walk the invoice items via a DB call to get the details needed for the Google tracker. It looks good on paper, now I'm going to give it a bit and see if/how it works.... more later.
Edit: Also, keep in mind this doesn't track recurring payments at all. (I.E. WHMCS generates an invoice and they come back to pay it.)
  • 6 months later...
If you need the total amount the order was for then you would use a code block like the below one to assign the {$amount} variable for use elsewhere in the template
{php}
$orderid = $this->get_template_vars('orderid');
$result = select_query("tblorders","amount",array("id"=>$orderid));
$data = mysql_fetch_array($result);
$amount = $data["amount"];
$this->assign('amount',$amount);
{/php}
So that would then enable you to do something like this in your tracking code:
<img src="http://order-tracker.com/?ordernumber={$orderid}&amount={$amount}" width="1" height="1" border="0" />
Matt
Now what about paypal where they may not be redirected back to order complete? Do something in paypal IPN?
  • 1 month later...
Yes, I don't understand why developer don't want to show it in Documentations...
You can place tracking code to
templates/orderforms/default/complete.tpl
(if you are using "default" order form)
{if $ispaid}
{literal}
<!-- Google Code for Purchase Conversion Page -->
<script language="JavaScript" type="text/javascript">
var google_conversion_id = 12313131313;
var google_conversion_language = "en_US";
var google_conversion_format = "1";
var google_conversion_color = "666666";
if (1.0) {
{/literal}
var google_conversion_value = {$amount};
{literal}
var google_conversion_label = "Purchase";
</script>
<script language="JavaScript" src="http://www.googleadservices.com/pagead/conversion.js">
</script>
<noscript>
<img height=1 width=1 border=0 src="http://www.googleadservices.com/pagead/conversion/12313131313/?value=1.0&label=Purchase&script=0">
</noscript>
{/literal}
{/if}
  • 1 month later...
Hi Dimak
Thanks for the code!
Don't you also need to post the amount for noscript?
{/literal}
<img height=1 width=1 border=0 src="http://www.googleadservices.com/pagead/conversion/12313131313/?value={$amount}&label=Purchase&script=0">
{literal}
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
Any update on this? With no response from WHMCS I'm assuming they either dont care or don't have an answer. The wiki information on this topic is very basic and not very good either.
I'm testing something out now but a definite answer would be helpful because it takes a few days to collect data and be able to tell if its working.
  • 2 months later...
{if $ispaid}
<!-- Enter any HTML code which needs to be displayed once a user has completed the checkout of their order here - for example conversion tracking and affiliate tracking scripts -->
{/if}
Is this still what we'd use to track conversions, or have things changed over the past 2 years?
We're receiving inaccurate results all over the place.
We want to add all of our tracking pixels to where they're executed before the payment redirect.
Basically, once the user checks the box to agree to the TOS and clicks Submit it then executes all of our tracking pixels etc regardless of payment. We can write scripts to go through and validate valid conversions later. This current setup is just too unreliable as people will pay with paypal and not come back to the complete page. Some people pay via credit card later on and don't see the complete page as they login through /billing/ to do it etc
Is there any way this can be possible?
You may put your Google Conversion Tracking Code in complete.tpl and under settings, set " Just show the order completed page (no payment redirect)"
