mbrando Posted March 12, 2025 Share Posted March 12, 2025 cannot login to https://www.whmcs.com/ page blinks then I get what looks like a page with no CSS. I have tried private window and 3 different browser. I had a friend check from his computer and he gets the same. I need open a ticket. 0 Quote Link to comment Share on other sites More sharing options...
RadWebHosting Posted March 12, 2025 Share Posted March 12, 2025 Hi, it's working fine for me. Can you please try again? 0 Quote Link to comment Share on other sites More sharing options...
bear Posted March 12, 2025 Share Posted March 12, 2025 (edited) Loads fine in Firefox, but Vivaldi (and a few others) sees what he does. Related to a javascript that's loading. It's a webpros script. Edited March 12, 2025 by bear 1 Quote Link to comment Share on other sites More sharing options...
mbrando Posted March 12, 2025 Author Share Posted March 12, 2025 I tried, still does not work for me. It is preventing me from open tickets. Thanks for letting me know it is a webpros script. They are tainting everything they touch. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted March 12, 2025 Share Posted March 12, 2025 If you're using Firefox, consider grabbing the "noscript" addon. It will allow the page to load. You have the choice of lowering blocks, disabling them all...or just finding the problem script and block it completely. 😉 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Technical Analyst Solution WHMCS Areeb Posted March 12, 2025 WHMCS Technical Analyst Solution Share Posted March 12, 2025 Hi @mbrando, Thank you for bringing this to our attention. I've submitted a report to our IT team to have this issue resolved. Best regards, Areeb 0 Quote Link to comment Share on other sites More sharing options...
mbrando Posted March 13, 2025 Author Share Posted March 13, 2025 12 hours ago, bear said: If you're using Firefox, consider grabbing the "noscript" addon. It will allow the page to load. You have the choice of lowering blocks, disabling them all...or just finding the problem script and block it completely. 😉 Thank you. I'll try this. 0 Quote Link to comment Share on other sites More sharing options...
