I don't understand what is happening, the pwreset.tpl file in the six theme is empty, and the one in the theme I use is with this continuous.
Now I notice that a file named pwresetvalidation.tpl
The theme has not received an update for 2 years, and the author removed the whmcs version from what I noticed. When I bought the theme it had no problems.
<div class="logincontainer">
    {include file="$template/includes/pageheader.tpl" title=$LANG.pwreset}
    {if $loggedin}
        {include file="$template/includes/alert.tpl" type="error" msg=$LANG.noPasswordResetWhenLoggedIn textcenter=true}
    {else}
        {if $success}
            {include file="$template/includes/alert.tpl" type="success" msg=$LANG.pwresetvalidationsent textcenter=true}
            <p>{$LANG.pwresetvalidationcheckemail}</p>
        {else}
            {if $errormessage}
                {include file="$template/includes/alert.tpl" type="error" msg=$errormessage textcenter=true}
            {/if}
            {if $securityquestion}
                <p>{$LANG.pwresetsecurityquestionrequired}</p>
                <form method="post" action="pwreset.php"  class="form-stacked">
                    <input type="hidden" name="action" value="reset" />
                    <input type="hidden" name="email" value="{$email}" />
                    <div class="form-group">
                        <label for="inputAnswer">{$securityquestion}</label>
                        <input type="text" name="answer" class="form-control" id="inputAnswer" autofocus>
                    </div>
                    <div class="form-group text-center">
                        <button type="submit" class="btn btn-primary">{$LANG.pwresetsubmit}</button>
                    </div>
                </form>
            {else}
                <p>{$LANG.pwresetemailneeded}</p>
                <form method="post" action="{$systemsslurl}pwreset.php" role="form">
                        <label for="inputEmail">{$LANG.loginemail}</label>
                        <input type="email" name="email" class="form-control" id="inputEmail" placeholder="{$LANG.enteremail}" autofocus>
                    </div>
                    </div>
                </form>
            {/if}
        {/if}
    {/if}
</div>
Try creating a file called "theme.yaml" in your template root (i.e. /whmcs/templates/yourtemplate/theme.yaml) with similar contents:
name: "My Custom Theme"
author: "My Custom Theme Author"
config:
  parent: six
See if this helps you to at least serve actual pages when accessed. Then work on updating according to your requirements.
