Rosendo Posted June 12, 2022 Share Posted June 12, 2022 Hello, I'm having a problem in the products and services section, specifically with the URL. Immediately after store/ another slash is added, which when you want to "buy" the product, a redirection is generated and it doesn't work. Image: I would like to know how I can fix this situation from the root. I already tried rewriting the url structure anyway but it doesn't work. I would greatly appreciate some help. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted June 13, 2022 WHMCS Product Manager Share Posted June 13, 2022 Hi @Rosendo, What is the WHMCS System URL value under Configuration > System Settings > General Settings, please? It should end with a single trailing slash. 0 Quote Link to comment Share on other sites More sharing options...
Rosendo Posted June 13, 2022 Author Share Posted June 13, 2022 Thanks for the reply. I've been checking and everything is fine. Even when I try to add new products the double bar does not appear. The double // appears only on products and services that I imported from another WHMCS installation. I haven't found a way to fix that. 0 Quote Link to comment Share on other sites More sharing options...
Rosendo Posted June 30, 2022 Author Share Posted June 30, 2022 I have finally found a solution. The problem was that after importing products, the URL of the product groups was not set and was blank. When I assigned a specific URL to each product group the problem was solved. 1 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted July 4, 2022 WHMCS Product Manager Share Posted July 4, 2022 Hi @Rosendo, Thanks for the follow-up. Case #IMPORT-6000 is open with our developers in order to have this reviewed for future releases of ImportAssist. I apologize for the inconvenience, and appreciate your patience as we work to resolve this. Thanks again for taking the time to report your findings. We welcome bug reports at https://bugs.whmcs.com/ 0 Quote Link to comment Share on other sites More sharing options...
