mario.fadegnon Posted June 22, 2020 Share Posted June 22, 2020 Hello, My clients are not able to change their nameservers through their interface.Actually their DNS are replaced by our default DNS. Please, help. Regards 0 Quote Link to comment Share on other sites More sharing options...
Brad (SaneChoice Limited) Posted July 3, 2020 Share Posted July 3, 2020 Hi Mario, Could you send a screenshot to help with this one? Thanks, Brad 0 Quote Link to comment Share on other sites More sharing options...
yggdrasil Posted July 11, 2020 Share Posted July 11, 2020 On 6/22/2020 at 6:03 AM, mario.fadegnon said: Hello, My clients are not able to change their nameservers through their interface.Actually their DNS are replaced by our default DNS. Please, help. Regards You need to provide more information and details. It's hard to guess the problem otherwise. What module are you using? What happens when they try to change their nameservers? What nameservers are set instead on the registrar or if you make a Whois lookup search? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Dan Posted July 14, 2020 Share Posted July 14, 2020 (edited) It sounds like your clients may not be selecting the "Use custom nameservers (enter below)" option when entering their nameservers. If the radio option is set to "Use default nameservers", even if the client enters custom nameservers in the fields then your default nameservers would be applied instead of the custom ones they entered. Edited July 15, 2020 by WHMCS ChrisD Removed background from formatting paste 0 Quote Link to comment Share on other sites More sharing options...
mario.fadegnon Posted July 16, 2020 Author Share Posted July 16, 2020 (edited) On 7/3/2020 at 10:18 PM, sanechoice said: Hi Mario, Could you send a screenshot to help with this one? Thanks, Brad Thank You Here are screenshots. Examinating my queries data, I find the new DNS but no change really Edited July 16, 2020 by mario.fadegnon 0 Quote Link to comment Share on other sites More sharing options...
mario.fadegnon Posted July 16, 2020 Author Share Posted July 16, 2020 On 7/14/2020 at 7:46 PM, WHMCS Dan said: It sounds like your clients may not be selecting the "Use custom nameservers (enter below)" option when entering their nameservers. If the radio option is set to "Use default nameservers", even if the client enters custom nameservers in the fields then your default nameservers would be applied instead of the custom ones they entered. Hello Sir, Please can you show me screenshot of the radio. It is not on my interface Regards 0 Quote Link to comment Share on other sites More sharing options...
