Is it possible and safe to setup production installation and dev installation to connect to same server?
It works, but it's not advisable.
On production environment you should have a number of different protection measures (firewalling, IP filtering, 2FA etc.) which would be annoying and time-consuming in dev environment...
Beside this, in dev you should also test server-level operations (i.e. OS update, PHP update etc.) which you can't do freely if you're in production environment.
At last: it may be confusing. If the system is the same, it may happen that you wrongly operate on production, instead that on dev...
