SSL not working for dologin.php and clientarea.php help needed
  • WHMCS Support Manager
The error under the "protocols" section is an issue with your server configuration and will need to be addressed by your server administrator.
The second issue is due to mixed HTTP/HTTPS content. This will mean that either your SystemURL under Setup >> General Settings is not set to use HTTPS or you have a custom form that will need to be updated to use HTTPS.
