About Using More than two seperate servers.
Hello all,
Recently I was trying one experiment but it doesn't work as I expected.. Im not saying it didn't work at all but not the way I wanted..
I have just setup a second server in WHMCS. Would it be possible for WHMCS to set up automation on 2 separate servers at the same time like this? -
Hosting Package 1.
Upon hosting payment and domain name sign up -
WHMCS will set up Server 1 automatically with nameservers:
ns1.mydomain.com
ns2.mydomain.com
Hosting Package 2.
WHMCS will set up Server 2 automatically with nameservers:
ns3.mydomain.com
ns4.mydomain.com
What are the steps to set this up correctly?
Also, I see a "default" server with "*" indicator for automation set-up. If I set the second server to default, does that mean that I will lose all automation for server 1? Also what happens when the auto suspension/termination kicks in for server 1 when cron jobs run? Will it be ignored since server 2 is the new default?
I made another group for another server but its showing that 'server not found' error.. Is it cause by not being set as default server? or it will be still get provisioned when order is get accepted..? and what is the process to work on tis situation?
Beacuase my one server is from my hosting provider (coz im a reseller) & another server is from amazon aws which is created by me and it also working fine and everything is ok, except the problem that I mentioned (refer screenshot)
P.S. All servers are cPanel servers. Thanks..
Hi @pratik_asabe,
Have you been through all of the steps in setting up the servers, especially the penultimate point about Test Connection?
https://docs.whmcs.com/Servers#Adding_a_New_Server
What happens when you do this with the one that gives you the "server not found" error?
Also have you setup the server group correctly for each of the products?
Edited by Vox
Yes I did everything and I noticed that even if we add two servers separately in having separate group for each of the servers it will fetch packages from default server only but this does not cause any error, we can still take orders but difference is at the time when we accept the order we have to select manually on which server this client should go.. it needs bit of logic to do all automation, its not full automation its kind of a semi-automated process.. and btw, thanks for guiding me.. appreciate it.. 🙂
