giudenapoli Posted March 22, 2018 Share Posted March 22, 2018 Hey there, I'm having some issues with OpenSRS Pro module cause OpenSRS doesn't update it frequently and I was wondering what difference I have with the OpenSRS standard module on WHMCS? I'm using WHMCS 7.5 rc1 and as I said with OpenSRS Pro module I have a blank page. Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted March 23, 2018 Share Posted March 23, 2018 Hey @giudenapoli Thanks for your post, firstly, i've moved this to the right board, you had posted this is a board for assistance with the community instead of WHMCS itself. Whilst we don't have an exact comparison list the built-in Module supports the registration, renewal and transfer of domains along with Registrar Lock, Name Servers, WHOIS Updates, EPP Codes & Connects with our Domain Sync Cron https://docs.whmcs.com/OpenSRS OpenSRS Pro adds support for other features such as domain privacy and a few other features, at this time they only seem to support up to WHMCS V7.1 I suspect that they do not support PHP 7.1/7.2 which may be why you are getting a blank page, have you tried enabling display errors under Setup > General Settings > Other and regoing to the page to see if this resolves the issue? 1 Link to comment Share on other sites More sharing options...
giudenapoli Posted March 23, 2018 Author Share Posted March 23, 2018 Unfortunately enabling Display Errors does not return any error messages for me. Link to comment Share on other sites More sharing options...
WHMCS ChrisD Posted March 23, 2018 Share Posted March 23, 2018 4 hours ago, giudenapoli said: Unfortunately enabling Display Errors does not return any error messages for me. Does anything show in your Module Log? Link to comment Share on other sites More sharing options...
wsa Posted March 23, 2018 Share Posted March 23, 2018 It looks like it doesn't work with V 7.4 or 7.5 look here Link to comment Share on other sites More sharing options...
