Orderform does not work with configurable options
Hello, I am new to WHMCS and I just integrated it into my website: http://bit.ly/2rLoiVJ
I had no problem with setup and configuration of WHMCS. All looks good. Even with the integration I had no problems.
I am using vultr addon for my server. Installtion without any error and problems.
However, after adding configurable addons, the orderform does not refresh and the continue button does not work anymore.
I cannot find out what's wrong. Can anybody help me?
could be a JavaScript error, check your browser console for any error records right after replicating the same steps again,
also try to use Standard_form template if you're using custom template
and check the Activity Log (Admin -> Utilities -> Logs -> Activity Log) for PHP/Database errors
