Help! zip=Postal Code is incorrect
9 minutes ago, ocastaned said:
UPDATE: Actually I contacted ResellerClub and they told me the module is created by WHMCS. They don't offer support about it.
to me, it sounds like they're passing the buck... or they didn't understand the issue.... I assume the module is working from the resellerclub API, and if the API expects a post code and doesn't get one, then it will throw an error.
but if you're saying that some LA countries don't use it, then a change to the API is likely required... you could try opening a ticket with WHMCS Support, but I suspect they'd just point you back to ResellerClub.
