nimonogi Posted October 14, 2017 Share Posted October 14, 2017 Hello, I'm getting the following error when i try connect my mailchimp account: Quote E-commerce Connection Failed Empty reply from server Any advice? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
nimonogi Posted October 14, 2017 Author Share Posted October 14, 2017 I have created a new mailchimp list and seems that it is working again. As I understand, you are not allowed to re-connect to a list that you disconnected your integration from it. 0 Quote Link to comment Share on other sites More sharing options...
nimonogi Posted October 14, 2017 Author Share Posted October 14, 2017 Another update: If you connected to a different list, then you can disconnect again and successfully reconnect to the first one. I guess this is some kind of a bug. 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted October 20, 2017 Administrators Share Posted October 20, 2017 Hi, This error suggests that your PHP configuration's PHP max_execution_time limit was reached before the initial synchronisation of products could complete. Please adjust your PHP configuration with a higher max_execution_time setting, and try again. 0 Quote Link to comment Share on other sites More sharing options...
