Using navbar hook code to place url link inside clientarea template?
I have a custom hook to add an item to my menu:
add_hook('ClientAreaPrimaryNavbar', 1, function (MenuItem $primaryNavbar) {
       $data=Capsule::table('tblhosting')->where('userid',$_SESSION['uid'])->where('domainstatus','Active')->first();
       if($data){
           $secondaryNavbar = Menu::secondaryNavbar();
           $contactUsLink = $secondaryNavbar->getChild('Account');
           $contactUsLink->addChild('map', array(
               'label' => Lang::trans('myserver_productdetailschange'),
               'uri' => 'clientarea.php?action=productdetails&id='.$data->id.'',
               'order' => 10,
I want to add a url link on the clientarea.php page to that same url link in the menu. I am uncertain how to unpackage the navbar hook code above to place new code inside clientarea.php. Is there an easy and fast method?
Thank you~
