issue with custom module
Remitur
Hello.
I'm writing a gateway module (mygateway.php), which need another stand-alone php file (mygateway2.php)
Both are in whmcs/modules/gateways/
mygateway2.php need to interact with db, so (according to http://docs.whmcs.com/Interacting_With_The_Database ) it begin with
use Illuminate\Database\Capsule\Manager as Capsule;
The problem is I get always an error of this kind:
PHP Fatal error: Class 'Illuminate\Database\Capsule\Manager' not found in /home/a856314wib/public_html/mydomain.ext/whmcs/modules/gateways/mygateway1.php on line 52
I tried with different paths, but or I did'nt guess the right one, or I lost some "include" which is necessary... :-(
Solved!
It was both a problem of include, and of relative path.
It was necessary to insert:
require_once __DIR__ . '/../../init.php';
require_once __DIR__ . '/../../includes/gatewayfunctions.php';
require_once __DIR__ . '/../../includes/invoicefunctions.php';
(the third one probably is useless, I have not checked it yet)
Thannk you for suggestion.
