hostservice_71 Posted November 10, 2015 Share Posted November 10, 2015 Hi, Since I'm not getting a response in the original thread: I'm on version 6.1.1 and installed this gateway. It looked simple, but doesn't seem to work for me. I use the standard six template. When I try to pay the invoice, and I select Bitcoin from the dropdown, a big white space appears in the upper section of the invoice. I assume this could be to display a qr code or so, but nothing happens. I'll give it another try of it works. Let us know, I'll be happy to donate if it works. Who has this working in 6.1.1. and what template do you use? Am I missing something? 0 Quote Link to comment Share on other sites More sharing options...
hostservice_71 Posted November 15, 2015 Author Share Posted November 15, 2015 Brian! helped out, there are two blockchain.php files, one of the main and one in the callback folder. Change both require(../../../dbconnect.php.... into init.php and you're good to go. Working well up till now. 0 Quote Link to comment Share on other sites More sharing options...
madsere Posted November 19, 2015 Share Posted November 19, 2015 Where did you find this addon? I don't see it in either whmcs standard api's or in blockchain.info's api's... 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted November 20, 2015 Share Posted November 20, 2015 Where did you find this addon? I don't see it in either whmcs standard api's or in blockchain.info's api's... http://forum.whmcs.com/showthread.php?76646-Bitcoin-Payment-Gateway 0 Quote Link to comment Share on other sites More sharing options...
