massa Posted April 8, 2015 Share Posted April 8, 2015 Hi, I'm using 2co as payment gateway. When user goes to "Create Automated Recurring Subscription" he gets error "Unfortunately your payment attempt was not successful. Please try again or contact support." In gateway log it says: Errors => Array ( [errors] => Array ( [0] => Array ( code => UNAUTHORIZED message => Authentication failed ) ) ) Does anyone knows what could be the problem? Please notice that make off payment is working fine, problem appeared only with recurring payment. 0 Quote Link to comment Share on other sites More sharing options...
sentq Posted April 8, 2015 Share Posted April 8, 2015 you may need to check the gateway configuration: http://docs.whmcs.com/2CheckOut Disable Recurring When ticked clients will only be able to make one-time payments (subscriptions disabled). For recurring services they will be required to login and pay each invoice. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted April 10, 2015 WHMCS Product Manager Share Posted April 10, 2015 Hi, This suggests that the API username and password under Setup > Payments > Payment Gateways are being rejected. Please double-check them: http://docs.whmcs.com/2CheckOut#API_Username.2FPassword 0 Quote Link to comment Share on other sites More sharing options...
