dacstyle Posted August 27, 2014 Share Posted August 27, 2014 After uploading the "dologin.php" file I'm still having the same redirect issue. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted August 27, 2014 WHMCS CEO Share Posted August 27, 2014 You must be experiencing a different issue. Please first try performing a full re-upload of all the WHMCS files and if you continue to have problems after that, please get in touch with our support team. Matt 0 Quote Link to comment Share on other sites More sharing options...
slim Posted August 27, 2014 Share Posted August 27, 2014 DID YOU UPLOAD INTO THE ADMIN FOLDER (or whatever you now call your admin folder) -- IT MUST GO HERE! 0 Quote Link to comment Share on other sites More sharing options...
ADz83 Posted August 28, 2014 Share Posted August 28, 2014 Warning: main(../init.php): failed to open stream: No such file or directory in /home/****/public_html/clients/dologin.php on line 0 Warning: main(../init.php): failed to open stream: No such file or directory in /home/****/public_html/clients/dologin.php on line 0 Fatal error: main(): Failed opening required '../init.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/****/public_html/clients/dologin.php on line 0 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Developer WHMCS Andrew Posted August 28, 2014 WHMCS Developer Share Posted August 28, 2014 This means you have uploaded the patch file to your WHMCS root rather than the admin folder as detailed in the patch notes. You will need to restore your dologin.php file in the WHMCS root (you can obtain this from the full version download) and place the patched file in your admin directory. 0 Quote Link to comment Share on other sites More sharing options...
capitan6682 Posted August 28, 2014 Share Posted August 28, 2014 Hi Andrew, already uploaded the dologin.php to admin folder but same issue occur. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Ryan Posted August 28, 2014 Share Posted August 28, 2014 As Matt suggested earlier did you try a full re-upload of all the WHMCS files? If not, please do so and if you continue to have issues you will want to open a ticket for further investigation. --Thanks 0 Quote Link to comment Share on other sites More sharing options...
HoangLoc Posted August 29, 2014 Share Posted August 29, 2014 Hi Andrew, already uploaded the dologin.php to admin folder but same issue occur. I was just like you. 0 Quote Link to comment Share on other sites More sharing options...
youknowwhoiam Posted August 31, 2014 Share Posted August 31, 2014 That's because install/install.php is wrong. it should be $hasher = new WHMCS_Security_Hash_Password(); $passwordHash = $hasher->hash($_REQUEST['password']); $apiPasswordHash = $hasher->hash(md5($_REQUEST['password'])); mysql_query(sprintf("UPDATE `tbladmins` set `password`='%s', `passwordhash`='%s' where `username`='%s'", $apiPasswordHash, $passwordHash, $_REQUEST['username'] )); $_REQUEST['password'] not $password, they are different. Hope they can fix it. 0 Quote Link to comment Share on other sites More sharing options...
Turboweb Posted September 3, 2014 Share Posted September 3, 2014 I had same issue with Yubico TFA after applying the update and hot fix. All I did to get it working is edited - tbladmins - for the admin user logging in - removed the authmodule field (in my case - yubico ). Then attempted a login - I got an alert saying admin tfa is required bla bla bla - entered the yubico key data - got the backup key and everything is working fine..checked the db and the authdata is where it should be 0 Quote Link to comment Share on other sites More sharing options...
