cosmin Posted June 4, 2014 Share Posted June 4, 2014 (edited) Hello! I have a little hook to change something in invoice before are sended to customer. From last WHMCS version didn't work and I don't undersnad why. I use InvoiceCreationPreEmail. Anybody have the same issue with InvoiceCreationPreEmail? Thanks! Edited June 4, 2014 by cosmin 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted June 4, 2014 Share Posted June 4, 2014 others are having a problem - so it is a known issue... http://forum.whmcs.com/showthread.php?89367-WHMCS-5-3-7-InvoiceCreationPreEmail-doesn-t-work-anymore 0 Quote Link to comment Share on other sites More sharing options...
altomarketing Posted June 6, 2014 Share Posted June 6, 2014 What problem are you having ? Did you try debuggin iit ? 0 Quote Link to comment Share on other sites More sharing options...
cosmin Posted June 7, 2014 Author Share Posted June 7, 2014 The problem is from latest release. WHMCS Team says in next release the problem with InvoiceCreationPreEmail will be solved. 0 Quote Link to comment Share on other sites More sharing options...
